K i wanted some opinions on how possible you think this would be, i just picked up my first fl250 project for $50, i build motorcycles, but never had a gokart, anyways for that price i got one frame, 2 engines, 2 drive shaft/transmissions and 2 sets of tires.. Mind you its all in pretty bad condition, engines will need full rebuild.. Heres what i have in mind
First i want to hinge the rear end off to get some kind of suspension, i have some left over shocks from a yamaha blaster that should work, then i want to spin the
Engine around so that its clutch belt thing what ever that's called is on the inside, so that i can mount the other Engine out the other side and have both drive shafts right next to each other in the middle
Then take both my drive axles, cut the one side off and mount both trannies on the inside, so both engines will be completly seperate from each other, this will also make the rear axle quite a bit wider, but i feel like itd make it quite a bit more peppy
