It is currently Sat May 17, 2025 10:17 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 20, 2014 1:32 am
Also a source for ball joint boots?
PostPosted: Sat Sep 20, 2014 1:36 am
Dave-Co wrote:
to you?? Your the one that were so sure these were pilot LOL Looks like it could be the one, The ball joints have the same numbers stamped on them, My son is going to cut them out tomorow, I will look it over when he gets the boots off. I cant see them not rotating any different than a pilots, will let you know, forsure cheaper unless you already have pilot arms to use.
I havent had enough stock pilot arms to tell the difference unless its pointed out to me. Only reason i was sure they were pilot was because i hadnt heard the ol switcheroo story yet. I knew bob took a set off of his pilot but didnt know they were switched out. But at least the balljoints seem to be the same. and hell yeah for $85 for a set if you don't have joints.. not a bad deal!
PostPosted: Sat Sep 20, 2014 1:42 am
Looks like there are enough of them, wonder if Honda still has them New? Stoked, great find, explanes why they are so much narrower for a smaller machine
PostPosted: Sat Sep 20, 2014 1:45 am
looks like they have one of them still for an 88-89 (assuming those would be the same as the balljoints on the pilot) http://www.partzilla.com/parts/search/H ... parts.html
looks like 86 and 87 used a different type of balljoint on the upper http://www.partzilla.com/parts/search/H ... parts.html
PostPosted: Sat Sep 20, 2014 2:07 am
Forsure don't want the early ball joints, that looks scary
PostPosted: Sat Sep 20, 2014 5:40 am
Hopefully the ball joints will work
Registered users: Bing [Bot], Google [Bot], liduno, MSN [Bot], Q
