It is currently Sat May 17, 2025 8:53 pm
PostPosted: Wed Dec 24, 2014 11:32 am
I have almost a whole Engine worth of parts.. and then some. good jug and head with oem ART piston with good rings with good compression....... and then another jug that needs bored/ or honed......and a nice clean crank needs a connecting rod bearing and rod........ etc.... case halves have all good seals and bearings...... what do you need let me know pics up when I get home just cleaned up all parts in parts cleaner table Pull start, electric starter, exaust tip , carb, flywheel almost everything Engine related lol, and exaust mounts, balance shaft and gears assembly, misc nuts and bolts
PostPosted: Wed Dec 24, 2014 2:54 pm
What are you asking for the crank?
Is the crank's connecting rod in good shape with no rod end play?
Thanks, Rand
PostPosted: Wed Dec 24, 2014 6:29 pm
Pm sent.
PostPosted: Wed Dec 24, 2014 6:39 pm
Svt198 wrote:
Pm sent.
Can you send the PM again please.....
I didn't receive one.
PostPosted: Wed Dec 24, 2014 7:20 pm
Thanks, Rand
Sorry just seen this crank needs new rod and bearing sorry it says so in the description almost all cranks ive seen do and are in worse shape than mine lol I seen kits but none in stock and there is 2 local shops one specializes in fl350s the other in all small motors and both want to much to separate and re press the 2 piece crank and possibly weld it
PostPosted: Wed Dec 24, 2014 7:25 pm
Thanks, Rand
I guess I didn't read thoroughly.
PostPosted: Wed Dec 24, 2014 8:53 pm
Svt198 wrote:
Pm sent.
Rand[/quote
Standby it's coming..........................
PostPosted: Wed Dec 31, 2014 2:07 pm
More parts
PostPosted: Wed Dec 31, 2014 2:15 pm
And more
PostPosted: Fri Jan 02, 2015 10:13 am
More parts: complete top end please no low ball offers
File comment: Comlpete top end kit with gaskets, piston, jug with good sleeve, exaust port and carb intake with reeds... only missing 3 studs (cheap) just needs a good bottom end to go on
File comment: Sleeve looks good nice and smooth
File comment: Nice oem ART piston with minor wear
File comment: Rings/piston look good had compression
File comment: And new gaskets
PostPosted: Mon Jan 05, 2015 3:52 am
Ok electric starter sold
Exaust pipe sold still have silencer tip
Airbox sold
Clutch sold
PostPosted: Wed Jan 07, 2015 10:33 am
Bumpers anyone want to buy the rest at a deal?
PostPosted: Wed Jan 07, 2015 6:11 pm
I also have the stator, CDI (Capacitor Discharge Ignition), most electrical
PostPosted: Tue Jan 20, 2015 6:21 am
Just sold the items listed below
Pull start assembly/cup
Stator
Flywheel
Thanks, to the post office around 4 will pm you pic of receipt with tracking info.
PostPosted: Thu Jan 22, 2015 7:29 am
To the top....... someone want to offer a fair price for the leftovers? Piston, crank, case halves with good bearings, head with jug and a little more make me a offer? Just want it all gone
PostPosted: Thu Jan 22, 2015 10:52 am
$50 for the crank
plus USPS priority mail medium flat rate box
thanks Speed
PostPosted: Fri Jan 23, 2015 4:20 am
$50 for the crank
thanks Speed
60 and its urs plus shiping and paypal of course lmao
PostPosted: Sat Jan 24, 2015 12:10 am
Ok liquid cool head sold!
Lots left
PostPosted: Sun Jan 25, 2015 9:16 pm
Need a stock intake for a 350, do you have one that's any good?
PostPosted: Mon Jan 26, 2015 3:03 am
Yes I do carb, rubber boot and reeds thanks
PostPosted: Tue Jan 27, 2015 8:45 am
Bump....
full harness 100.00
carb 100.00
case halves with bearings 80.00 ea
mint y fin head 35.00
mint jug 65.00 also have one that needs bored or honed 45.00
mint intake boot no cracks or stretch 45.00
piston 50.00
gaskets 20.00
reed ×2 40.00 ea
exaust manifold 20.00
balance shaft and gears 40.00
balance cover 20.00
starter mount bracket 10.00
crank (needs rebuilt) 50.00
painted like new muffler tip 50.00
exaust hangers ×3 15.00 ea
Gas tank 8/10 with fuel pump and oem keyd gas cap 150.00
im sure there is more lol will update as I find stuff
PostPosted: Mon Feb 02, 2015 7:50 am
Bumppp cheaper prices!!!!!
PostPosted: Wed Feb 04, 2015 8:42 pm
Bump....
full harness
Larger mikuni kogyo carb 175.00
mint y fin head 40.00
mint jug 65.00 also have one that needs bored or honed 45.00 SOLD both jugs
intake reed power spacer 15.00
piston 50.00
gaskets 20.00
reed ×2 40.00 ea
balance cover 20.00 SOLD
crank (needs rebuilt) 50.00 SOLD
PostPosted: Wed Feb 04, 2015 9:32 pm
you have a stub axle. I am making a custom rear end and I need just the portion from a broken on preferred that goes through the bearning carrier.
PostPosted: Thu Feb 05, 2015 2:15 am
No I do not sorry try asking B S
Registered users: Bing [Bot], c5racer, eseymour72, Google [Bot], liduno, MSN [Bot], Q
