It is currently Fri May 16, 2025 5:38 pm
PostPosted: Sat Jan 24, 2015 3:44 pm
Hello
I am in need of the transmission gear change arm for my Odyssey. The one I have is bent and doesn't grab the splines on the shaft sticking up and out of the transmission. Thanks in advance for the replies.
For clarification, this is the part that sits on top of the transmission and has splines similar to a motocross gear shift lever.
PostPosted: Sat Jan 24, 2015 5:07 pm
Number 4 ?
24516-VM0-000 ARM, GEARSHIFT
PostPosted: Sat Jan 24, 2015 7:12 pm
I believe he needs #9 under shift lever.
54531-VM0-000
PostPosted: Sat Jan 24, 2015 7:36 pm
Sorry, I should have included the pic and number. It is the piece listed in the shifter assembly as number nine.
Thank you.
