It is currently Fri May 16, 2025 5:21 am
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Mar 23, 2015 10:34 pm
Getting close .
Stixie don't forget the grill grate and the 2 prong frogg gig .
PostPosted: Mon Mar 23, 2015 11:31 pm
ChrisV wrote:
dbloudharleys wrote:
Welp no huggie no kissie without some spooning . But I am cheap
Bring the bacon ez I will fry it up . 609 , hope my rig will fit .see ya Sunday pull out my usual wed.
My freckling neck is killing me but I am going anyhow .
I can't wait .
Hey Chris if my rig won't fit If you are interested I might swap ya spots and put ya up in the rv .
No tents being pitched inside the rv though . :shock:
Ill be pulling in saturaday at lunch or maybe friday night and ill leave when i get too sore or everything is broke!
im having an injection in my neck on 3/31/15 so ill be good for the ride!!! if that don't work the hydrocodon will!! NO EXCUSES!!!
if your rig wont fit im sure we can work something out. maybe we can rig it up so the rides are secure when we are not around.
no backup buggy but i may bring this if i get it running in time
Maybe EZ can bring 400EX to help represent the quads
PostPosted: Mon Mar 23, 2015 11:33 pm
Getting close .
Roger that, finders fee's a fat Tbone. Also have spatula
PostPosted: Wed Mar 25, 2015 1:08 pm
oh no,
my 250r piston looks bad
PostPosted: Wed Mar 25, 2015 7:19 pm
ChrisV wrote:
oh no,
What happen?
PostPosted: Wed Mar 25, 2015 8:19 pm
I can't wait .
Looks fast, is this where the thrashed piston came from?
PostPosted: Wed Mar 25, 2015 9:52 pm
Getting close .
Yea I will need that too, it will make turning the T-bone over easier.
Good grief.
Well maybe the trip will be good with first tornado out of the way.
Moore hit again unbelievable. Looks like we are going to be in for a
super fun spring.
PostPosted: Wed Mar 25, 2015 10:37 pm
I can't wait .
it was :shock:
I have a stock cylinder with a new wiseco piston that I plan to put on it just top ride. it will be a bottom end dog with the huge carb and drag pipe
PostPosted: Wed Mar 25, 2015 10:39 pm
ChrisV wrote:
oh no,
What happen?
not 100% sure but the liner was cracked at all three of the narrow exhaust ports. all galling was on the exhaust side.
I sent the cylinder and piston to http://www.bdtmotorsports.com/ to be resleeved
PostPosted: Thu Mar 26, 2015 2:56 pm
if you look carefully at the left side of the exhaust port you can see the cracked sleeve. the middle and the right side are also cracked. im not sure of the cause of the cracks, but my guess is that this caused the galling. you can also see the flaked nikasil liner. that is a 76.XX mm piston with a 72mm stroke
i was not at full throttle and not beating on it. about 5 minutes into the ride after a 5 minute warm up
PostPosted: Thu Mar 26, 2015 6:01 pm
Who built that cylinder?
Nikasil coated iron liner?
PostPosted: Thu Mar 26, 2015 7:34 pm
yes, fairly common in big bore 250r stuff.
the whole Engine was built by FTZ racing.
carlos could not get my cylinder done by the ride so I bought a used (new bore) esr power valve seet up from him. I should have it Monday.
I kinda hated to go down in CC's but I want it ready for the ride.
PostPosted: Thu Mar 26, 2015 8:28 pm
Well at least you will have a back up, sorry for the carnage, hope the rebuild goes well
PostPosted: Thu Mar 26, 2015 10:30 pm
well I think I may have found the killer. if not it would have killed it. the vent line was clogged
PostPosted: Fri Mar 27, 2015 12:59 am
Hope the weather holds
http://www.wunderground.com/history/air ... reqdb.wmo=
PostPosted: Sat Mar 28, 2015 6:29 pm
stix wrote:
Lmao :-) really 91 wed watch it hit 100 or a nado .
Told ya Chris
Getting injected Monday in neck . It went from right side to left this sucks but really looking forward to riding. -::
PostPosted: Sat Mar 28, 2015 6:31 pm
Told ya Chris
I had to skip my injection due to a possible job interview that day. Norco to the rescue
PostPosted: Mon Mar 30, 2015 10:34 pm
Told ya Chris
Injections, 90 degree weather, Ill have a cold one wating for you when you arrive
PostPosted: Mon Mar 30, 2015 10:54 pm
Good grief got injection at about 2 probaby shouldn't have worked in the yard but I had limbs everywhere. Raked some leaves best my neck has felt in 3' months ! Talk about something holding out.
I told him if this doesn't work it's time for a plan b . I am done with injections and their stupid pain pills .
So for now going to start loading up trailer that way I don't forget anything .
Stix don't forget the frog gig the grill cover and spatula !!!!
I am going to load up some wood too .
Also going to make up some party favors for the pilots to no Eric I haven't forgot !
PostPosted: Mon Mar 30, 2015 10:59 pm
Since Im Pilot traitor Ill have to sit out on the party favors, save that neck for ridin not rakin. Glad your feelin better, I need to get back cracked at chiropractor before I go. I mloaded just have a few Tits and Tats to do on the Taz
PostPosted: Tue Mar 31, 2015 10:43 am
i got it back together!!! gotta do some heat cycles and break in today
BTW, anyone want a pilot gas tank?
PostPosted: Tue Mar 31, 2015 6:13 pm
Well you made quick work out of that
PostPosted: Tue Mar 31, 2015 9:45 pm
didn't have much time
3 heat cycles down
PostPosted: Fri Apr 03, 2015 7:04 pm
Headed out at 7am!!
PostPosted: Fri Apr 03, 2015 11:52 pm
Won't be there till Sunday night .
Gotta work tomorrow . Didn't realize Sunday was Easter , good grief .
Going to be with family for sunrise service .
See ya guy Sunday night .
