It is currently Fri May 16, 2025 5:16 am
PostPosted: Mon Apr 27, 2015 1:23 pm
I have a quick shift clutch now and it is no longer working correctly. It is sticking and not shifting correctly. When I come to a stop it will kill the motor (( Internal Combustion Engine ? )). Also when I ride at high speed it stays in high gear for a while before it comes back to low speed setting. So it boggs the motor (( Internal Combustion Engine ? )) down. If you have one you would like to sell or can tell me how to remove it please call me at (509)430-7733 Steve
PostPosted: Mon Apr 27, 2015 6:18 pm
viewtopic.php?f=1&t=14622
Sounds like it needs serviced see any rust on the Pilot like it sat outside or in a high moisture environment?
I do not know anything about the quick shift clutches try to find all the letter and numbers on the clutch and search the web, bring the info you found here and share.
CW Racing use to sell the quick shift clutches?
Clutch puller .
PostPosted: Mon Jun 22, 2015 12:45 pm
The "Feet" had broken off the weight arms and the spring was in three pieces.
