It is currently Thu May 15, 2025 7:12 pm
PostPosted: Sun Sep 27, 2015 9:50 am
Random ad i found on craigslist, the transmissions seem reasonably priced considering i've seen em for more than what i paid for my odyssey. or all those gears for $150 if anyone's looking to stockpile parts. only problem is he says no paypal who knows if he would ship it somewhere.
https://losangeles.craigslist.org/sfv/m ... 90447.html
from his post
DO NOT TEXT ME
Shocks and Belts Cases $150
Pull Start Air Box Belt Guard PARTS $100
Clutch Parts Lot $135
OEM motor (( Internal Combustion Engine ? )) Head $75
Transmission Gears Lot $150
Custom Aftermarket Dash for Water Gauge $75
K&N Filter $30
OEM Stator $150
OEM Voltage Regulator Retifier $40
OEM Final Drive Gear Shaft $75
OEM Shifter Gear Collar New old stock $70
OEM CDI (Capacitor Discharge Ignition) Ignition Black Box $180
OEM Connecting Rod 13201-KA4-700 NEW $95
GEARBOX TRANNY TRANSMISSION A/B GEAR $299
Transmission FL350R w/ Rear Brake Rotor Disc attached $325
Odyssey Transmission FL350R w/ Drive Pulley attached $300
Odyssey RIGHT Trailing Arm $90
Mikuni T38 Flat slide Carb Carburetor $100
Stock Transmission EMPTY Cases GOOD $150
Crankshatf Crank pulled from running Engine Good $99
Left Lower J Arm $90
Reed Valve Reeds $50
Rear Brake Tail Light $30
Right Lower J Arm $90
Right Upper / Lower J Arm $135
RIGHT Trailing Arm Assembly $140
Left Upper / Lower J Arm $95
DO NOT TEXT ME // NO PAYPAL // NO EMAIL // NO SCAMMERS
PostPosted: Mon Sep 28, 2015 3:02 pm
Would this be member "BS"?
http://www.pilotodyssey.com/PO/viewtopic.php?f=4&t=15226
PostPosted: Mon Sep 28, 2015 3:09 pm
That is to far south for BS, he is up around Sacremento. Plus he lives on PayPal and will talk,text,vox your ears off at times.
