It is currently Mon May 19, 2025 3:49 am
PostPosted: Tue Nov 03, 2015 9:00 am
Anyone ever tried ranger 900 shocks on there 350?
I have no idea of the length or the spring rates, but I can get set for cheap.
PostPosted: Tue Nov 03, 2015 9:10 am
According to a couple sellers on evilBay with tape measures in the pics, the 08-12 fronts are ~18" and the rear are ~16" E2E. But don't quote me on that. A lot of the Ranger stuff also fits the Rzr, so check their respective owner forums.
PostPosted: Tue Nov 03, 2015 12:39 pm
Those are not going to work.
The bottom of the shock requires a Heim joint to cycle through it's travel.
If they are truly 16 inch eye to eye then they are also too long and will cause the U joints to bind.
PostPosted: Tue Nov 03, 2015 1:25 pm
Plus the FL350R dry-weight is ~600-lb and the Ranger is more like ~1300-lb.
PostPosted: Tue Nov 03, 2015 1:27 pm
Survey says?.....
PostPosted: Tue Nov 03, 2015 2:41 pm
bwomp bwomp bwaa
PostPosted: Tue Nov 03, 2015 4:49 pm
I will be making an attempt to do something with the stock rear oddy shocks.
It will be done this winter while I redo the spare machine since mine is totalled.
Will post results and what I did in the near future here.
Jknarfal is doing the same.
PostPosted: Tue Nov 03, 2015 5:49 pm
I started messing with them but I've been extremely busy. And all my spare time is going into rebuilding my banshee before thanksgiving. But f any info is needed I'd be glad to share what I know.
PostPosted: Wed Nov 04, 2015 9:15 pm
Why does it need a heim joint?
PostPosted: Wed Nov 04, 2015 9:56 pm
As the suspension moves up and down so does the angle of the shock on an fl350
PostPosted: Thu Nov 05, 2015 2:24 am
Because of the design of the axle, when the suspension swings through it's up and down movements, the swing arm actually moves outward probably almost 2 inches. This necessitates the need for a Heim joint in the bottom of the shock. The top of the Showa shock has a steel bushing that is encapsulated in rubber which allows the shock to swing outwards. In my opinion, Honda should have used a Heim at the top of the shock also.
PostPosted: Thu Nov 05, 2015 9:49 am
This is where I got confused, I knew my stock shocks didn't have a heim joint.
PostPosted: Thu Nov 05, 2015 2:10 pm
What shocks are you using?
PostPosted: Thu Nov 05, 2015 2:33 pm
Just the stockers right now but they are beat.
PostPosted: Thu Nov 05, 2015 3:12 pm
The factory shocks have a heim joint at the bottom
PostPosted: Thu Nov 05, 2015 7:48 pm
Mine have all been a steel sleeve in a rubber bushing.
PostPosted: Thu Nov 05, 2015 10:10 pm
Please post pictures.
As Jknarfal mentioned, Showa Ody shocks have a heim joint in the bottom of the shock. Either your shocks are mounted upside down or you are running another type of shock.
PostPosted: Fri Nov 06, 2015 9:57 am
I Just went out and looked, unless I removed the shock all I could see is the bolt head. I thought it was just like the top, maybe I never looked close enough.
Learn something new everyday.
