It is currently Sun May 18, 2025 10:28 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 12, 2016 2:39 am
A lil more progress
File comment: Had my buddy Doug weld it in place I'm still a learning welder lol
PostPosted: Sun Feb 14, 2016 7:35 pm
Done lol I had the confidence to weld today so I finished up the project myself looks great grinded more after last pic capped the inner frame with washers welded in
PostPosted: Mon Feb 15, 2016 3:35 pm
Its coming along! You're already ahead of the one I started...like 2.5 yrs ago! haaa
Did you buy a header pipe from Farr? If you're going to DIY the pipe check my project log on my FL470. It wasn't too difficult to cut/patch/weld the pipe and the 2-to-1 flange to fit behind the stock seat. Just thinner steel, that's all. Granted I haven't even started that Engine since I put new piston & rings in it.
Nice to see someone show their actual welds in a photo. The more you weld the less grinding you'll have to do. Kudos, man! :-) Is that with gas or flux-core wire? I'm certainly no expert, but be sure to clean-up the joints before you weld with a grinding wheel or tiger-paw pad. Get rid of that mill scale, and wipe it down with acetone or non-chlorinated brake kleen. Contamination kills a weld, even MIG.
PostPosted: Tue Feb 16, 2016 1:09 am
Thanks making my own header pipe I need one tho do you have one, and it's a gas welder,
PostPosted: Wed Feb 17, 2016 10:22 pm
Nope, I don't have any extra skidoo headers.
Here's a 96 670 pipe for $50..https://detroit.craigslist.org/okl/snw/5444392684.html
PostPosted: Wed Feb 24, 2016 3:33 am
