New post from Loss of Compression post(
viewtopic.php?f=1&t=16807 )- now a carb issue so new thread
First year pilot owner so still learning. A lot.
Extensive rebuild and (almost complete) restoration that ran great for two months. Then it melted the rings out of the blue. Since then,
Engine has had leak down test and fuel pump test done, and passed. Twice. And eaten two more pistons for lunch on my tab. Carb has been cleaned and checked(?) and seemed to be jetted well until it leaned out the first time. All rebuilds went through the Hoser recommended break in (
viewtopic.php?t=3114 ) prior to attempting to re-jet. Never able to get it right, Always started and idled well but regardless of jet size, from 160 which was the original jet it ran great on for two months to 182 which ran like crap off the line until you could get rpm's up all came up gray on a plug chop and never got more than 15 minutes of riding at 3/4 throttle after break in before it got hungry - symptom of an air leak.
Picture of piston(s). They are shown in order if use.
Here's the question: Using a 39mm Keihin - will a throttle cable with the plastic covering worn offof the end where it fits into the top of the carb cap leak enough air in to lean out the Engine? Here's what i started with:
There was a pretty big area around the metal of the cable where the plastic had worn away and the housing that it was fit into with nothing to stop airflow.
Here is the after with a little help from some heat shrink tubing (any better ideas for this are welcome also):
Could really use feedback from anyone on this. The Engine and intake do not leak. What is left but the carb?
More time fixing than riding, not cool.
Thanks for any help.
Dave
