It is currently Thu May 15, 2025 1:54 am
PostPosted: Fri Oct 21, 2016 9:27 am
This may be a long shot but I need Engine mounts for a FL350R. If anyone should have a set, just a few, or just one, I would be interested in purchasing them.
Qty & Part #'s
4 X 50241-VM0-000
3 X 50202-461-000
1 X 50242-VM0-770
If anyone knows of another option please let me know.
PostPosted: Fri Oct 21, 2016 10:36 am
This is going to become a big issue for fl350s and fl400s in the future. We need a aftermarket solution.
PostPosted: Fri Oct 21, 2016 5:30 pm
I hoserize all my Pilot mounts viewtopic.php?f=25&t=6997
Other talk about mounts viewtopic.php?f=1&t=12015
PostPosted: Fri Oct 21, 2016 8:28 pm
I actually bought a Suzuki mount but it is not the correct size. There is a write up on it here somewhere.
Also one of our English members made a set from the correct durometer rubber. He cast it. Can't remember the post right now. I was looking into making some myself just like the member from England but I lost interest, even though I got all the info. I think you will most likely have to cast your own because I did a lot of looking and even purchased the Suzuki unit. Side note here: silicone won't work, it's the wrong durometer, D$ tested it on a durometer machine. Also the CB1000 mounts are no longer available either.
PostPosted: Fri Oct 21, 2016 8:30 pm
Here is that post on the Suzuki unit.
viewtopic.php?f=1&t=16483&hilit=suzuki+mounts
PostPosted: Fri Oct 21, 2016 8:35 pm
Here is the post from Dan in England:
viewtopic.php?f=1&t=10899
By the way I did contact him not to long ago (July26/16) and he said he was gona post results. He must have forgot.
PostPosted: Wed Oct 26, 2016 8:54 am
A member here was kind enough to let me purchase a set of Engine mounts. Thank you!
The other threads on this topic are very good for repair and replacement. Member "Dan" seems to have made a good aftermarket replacement using the poly resin. I am all set for now but will likely have to hoserize the mounts one day.
On a side note, has anyone had success with the CB1000 Engine mounts? They are more readily available then the fl350 /pilot mounts. Although they look similar, they are not the same. (not to say they can't work)
http://www.ebay.com/itm/HONDA-CB1000C-C ... FK&vxp=mtr
PostPosted: Wed Oct 26, 2016 5:04 pm
I did check to see if I could get some Honda mounts like the 1984 cb700sc but they are no longer made or in stock, so I came up empty handed. Several of the early Honda's of that year used the same mount, but not sure about the CB1000. I think "Dan" has the answer though.
Registered users: Baidu [Spider], Bing [Bot], FL670R, Google [Bot], Lanix, stix
