It is currently Wed May 14, 2025 7:12 pm
 Post subject: Parting Out 89 FL400
PostPosted: Thu Jan 05, 2017 10:36 pm
Has been in storage for last 3 years. Seized Engine, but everything else was working.
Great for extra parts. Will negotiate price if you want it all.
Parts Include:
Seat/Mounting Bracket $200
Tub Plastic $200
Frame/Cage $700
Rear Axles/CV $200ea
Rear Knuckle Axle Housing $150ea
Axle Hub $50ea
A-Arms $25ea
Control Arms $25ea
Shocks $20ea
Brake Assembly $100
Front Knobbies 85% Tread $30ea
Aluminum Wheels $30ea
Engine Case $350
Transmission $600
Steering Wheel w/Brakes/Master Brake Cylinders $250
Steering Column $50
Fuel Tank $200
Carburator $150
Rear Brake Light $45
Reduction Gear $190
Side Plastic $100
Battery Cage $70
Roof Plastic $65
Seatbelt/Harness $75
ECU/Coil $125
Tie Rods with ends $35
Safety Nets $50
Starter Relay/Fuses $40
Wiring Harness $100
Make offer!!! Need to create room for next toy
 Post subject: Re: Parting Out 89 FL400
PostPosted: Fri Jan 06, 2017 1:54 am
id be interested in the rear caliper with all the springs & such
if the side plastics are good with no cracks or repairs id be interested in those too.
PostPosted: Fri Jan 06, 2017 2:47 am
So that works out to about $5000 for something that needs a complete re&re :shock:
Can't you get a running one for a little over the same price ??
PostPosted: Fri Jan 06, 2017 6:17 am
What are you referring to when you say "reduction gear"?
I'm interested in the axles providing they are good.
Regards.
PostPosted: Fri Jan 06, 2017 9:52 am
https://orangecounty.craigslist.org/snw/5947273554.html
PostPosted: Fri Jan 06, 2017 8:39 pm
Very true. Those prices are for parts individually. If you want everything, I will let it go for $1500, as scpilot66 has shown with my craigslist post.
PostPosted: Fri Jan 06, 2017 8:43 pm
I will take pics of the parts and post tomorrow. As you can see, its not torn apart yet, so I will get as detailed shots as i can
PostPosted: Fri Jan 06, 2017 9:25 pm
So you are about an hour north of Oceanside?
PostPosted: Fri Jan 06, 2017 10:44 pm
A little less if traffic is moving. Just past San Juan Cap
PostPosted: Mon Jan 09, 2017 7:38 am
PM sent.....
PostPosted: Wed Jan 11, 2017 4:10 pm
Thanks for all that were interested.
Pilot/all parts has been SOLD!!!
Registered users: Baidu [Spider], Bing [Bot], Google [Bot], Rppjr
