fuesselfc wrote:
Hoser, I always try searching site first before asking questions, this is definitely the best forum board I have been on! Love the site, organization of it, and people on it are incredible help.
so looking at diagram above, I thought part 8 was the adjuster and one of them turned sideways! What exactly is part 8 and is it supposed to turn sideways?
So #12 & 16 is was adjusts the pads in and out correct?
If that is a wheel cylinder on top, is that another cylinder on bottom or just a pad holder and adjuster?
Thanks for the assistance!!
Part #8 is the retainers for the brake shoes you will see and understand once you remove the drums.
12 & 16 are the adjusters you will see them in the holes in the front side of the drums the holes are about 1/2" diameter and have rubber plugs covering them a small straight blade screwdriver is used to adjust them. I forget what way to turn them to loosen you will have to play with it, when you turn them a while and you can no longer spin the drum you know your going the wrong direction haha
