It is currently Tue May 13, 2025 11:22 am
 Post subject: 600 ho pilot
PostPosted: Fri May 27, 2016 1:59 am
I decided to go with a Engine that I can use the correct carbs with. Farr Off road found a 600 ho Engine 2006 I believe. It has the same hp as the 670. I will need to refab the cross bars some but overall the install has gone great.
 Post subject: Re: 600 ho pilot
PostPosted: Fri May 27, 2016 2:02 am
More
PostPosted: Fri May 27, 2016 8:08 am
Holy crap :shock: I thought you were saying 600 horsepower! :shock: :-)
PostPosted: Fri May 27, 2016 11:30 am
So why not go with the 600 sdi. Get rid of the carbs and still in the same hp range.
PostPosted: Fri May 27, 2016 11:44 am
I've never seen one is it like the 600 etec
PostPosted: Fri May 27, 2016 12:47 pm
Yeah they are similar. Believe they came out in 04. My dads has one. Sdi is semi direct injection
PostPosted: Fri May 27, 2016 3:16 pm
I looked up a couple of them and it looks like almost the exact same Engine. They both have Reeds and they sit up high so they will clear the transmission. I wonder if the electronics will fit in my Engine so I could use the same fuel injection
PostPosted: Fri May 27, 2016 3:52 pm
I am not sure. I bet if you went over to doo talk they might know
PostPosted: Sat May 28, 2016 3:57 pm
What sled did that motor (( Internal Combustion Engine ? )) come off of?
PostPosted: Tue May 31, 2016 2:45 am
Not sure, but I know it is a 06
PostPosted: Sat Jul 02, 2016 12:39 am
60 mxz 600 ho with 800 Reed cage and boots with 600 carbs. I think I have it down to run all the 670 electronics. Way easier. Farr off road is thinking the 670 and 583s are a thing of the past. If I get this running on the 670 stater and mag this is a way better Engine. More hp then the 670 too. I might look at what it will take to get the sdi going. Wiring the 600 with the 670 wiring was a piece of cake.
PostPosted: Sat Jul 02, 2016 12:48 am
First start up https://youtu.be/ULIYrI0aRVs
PostPosted: Sat Jul 02, 2016 2:26 pm
Sounds awesome! Great build. Love the room you have also with the fabbed caged. Did you make it?
PostPosted: Sat Jul 02, 2016 3:43 pm
That looks like a dave co cage, similar to mine in fact.
PostPosted: Sat Jul 02, 2016 5:10 pm
How much did it run you?
PostPosted: Sat Jul 02, 2016 7:47 pm
Yes its a Dave Co cage. We just changed the rear shock mounts
PostPosted: Fri Jun 02, 2017 12:39 am
Been busy but Im getting back on my pilot. We are rebuilding the rear arms and links first. Ill get pictures as soon as i get them going.
PostPosted: Fri Jun 02, 2017 3:28 pm
No worries Chris, it hasn't even been a year :-)
