It is currently Wed May 14, 2025 7:17 pm
PostPosted: Fri Jul 07, 2017 10:52 pm
Does anybody have any or can get them? if not, what do you suggest? Thanks.
PostPosted: Fri Jul 07, 2017 11:15 pm
Hoserize your old mounts.
viewtopic.php?f=4&t=17050
PostPosted: Fri Jul 07, 2017 11:54 pm
Or make your own: viewtopic.php?f=1&t=17228
PostPosted: Sat Jul 08, 2017 9:20 pm
If I had some old ones I would make my own. Do not have any.
PostPosted: Sun Jul 09, 2017 8:47 am
http://www.ebay.com/itm/112470658415?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
http://www.ebay.com/itm/182652525438?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
there speed
PostPosted: Thu Jul 13, 2017 10:58 pm
I have a full set
PostPosted: Fri Jul 14, 2017 2:03 pm
Have you ever tested these?
PostPosted: Fri Jul 14, 2017 3:39 pm
I sent two of these to solo0879 and he was suppose to file a report. He didn't and he hasn't been on the site since Feb 16/17. I shipped them FREE and gave them to him FREE. I am a bit discouraged actually, as I just wanted to know if they were any good. Didn't want to rip my machine apart just for a test. I did make several intakes and one is on my machine right now. It works awesome, no issues. However we have not been on many rides this year (about half a dozen). The intakes are good.
PostPosted: Fri Jul 14, 2017 3:51 pm
I see that Vanelayindustries has a set for sale for you.
Another option would be to take a long piece of inner tube and wrap it around a piece of pipe. You could use contact cement to hold the inner tube together and in place. Weld a washer on one end. Put a bolt through and a big washer on other end. Good to go.
I believe the stock mounts are about a Shore A60 hardness and inner tube is Shore A35 hardness, but there will be multiple layers so you should be good.
PostPosted: Mon Jul 17, 2017 6:45 am
Do you mind if I make my own out of your "Design" i guess that's what you would call it?
I have my restoration going and I would love to have better Engine mounts!
PostPosted: Mon Jul 17, 2017 11:57 am
Build away kid :-) .
Be sure to post your progress. Pics Pics Pics :-)
I would send you a set but I think from now on I will just be helping out with information.
Unless someone has been here 10 years and has at least 500 posts I think all I will provide from now on is tech help.
PostPosted: Mon Jul 17, 2017 3:29 pm
Cool, it will be a while but ill post those pics!
Registered users: Baidu [Spider], Bing [Bot], Google [Bot], Rppjr
