It is currently Mon May 19, 2025 4:56 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sat Oct 28, 2017 9:19 am
So it is 4.5oz at 10 seconds cranking. Or 4.5 at idle? I read the pilot was 4.7 at 10 seconds idle.
Is this my problem?
PostPosted: Sat Oct 28, 2017 12:10 pm
Is this my problem?
I don't run my machine when I check it.
I just remove the hose from carb and crank it with the starter.
PostPosted: Sat Oct 28, 2017 12:17 pm
I never have to prime my pumps. Just bolt on and go. But maybe try to prime it and see if it helps. Something very wrong here but I don't know what it is at the moment. Don't know what to suggest.
PostPosted: Sat Oct 28, 2017 4:43 pm
I just solved it. I was bench testing. So I put a carb on the Engine. It shot right to 4oz. I took the carb off and got 2oz. Don't know how to explain it but I am getting 4oz now.
When carb is on you see no bubbles in my clear fuel lines. . Just solid fuel. When carb is off you see bubbles.
