It is currently Mon May 19, 2025 5:40 pm
PostPosted: Sun Mar 07, 2004 10:30 am
Let's see how long (or even if) this repair lasts. At least its better than a large, dirt collecting hole in the boot. I found the replacement boot at the local Pep Boys for $4.99.
PostPosted: Mon Oct 09, 2006 9:07 am
PNut - how did this work out for you? I got to replace mine and was reading through all the old posts. Lemme know. Thanks!
Brooks
PostPosted: Mon Oct 09, 2006 9:20 am
Are the fronts and rears the same size boot?
viewtopic.php?t=237
PostPosted: Mon Oct 09, 2006 12:36 pm
no,
Front upper & lower are the same, rear has a smaller ball joint body dia (stud is the same dia).
PostPosted: Mon Oct 09, 2006 2:50 pm
I used the same boot on both the front (upper and lower) and rears. Honda #53546-611-310. (from the Honda car dealer).
The front boot fit perfectly but they do not press on like the OEM, I had to glue them on.
For the rear the sealing area of the boot is larger then the original, but there are two machined areas on the rears. The boot fits perfectly on the larger machined area. (lip where the joint presses in)
I glued the boot on and they have held for about two years now. I'll put picture of the rears up tonight
If you do a search for "ball joint boot" there is a picture of my a arms with the boot installed.
PostPosted: Mon Oct 09, 2006 3:56 pm
This the pic?
DC ball joint boot
Pilot rear ball joint boot.
Replacement ball joint boot.
Honda 53546-611-310 looks discontinued now wonder if measurments could be taken off the ball joint itself and a exact fitting boot bought here http://www.prothanesuspensionparts.com/Prothane-Ball-Joint-Dust-Boots.asp
Searching for that Honda part number returned this application?
SEAL, BALL JOINT - 1979 HONDA ACCORD SEDAN (53546611310)
http://www.ezhondaparts.com/oem-part/ho ... 46-611-310
Further searching Part#: 53546611310 returns this part http://www.hondapartswebsite.com/OEMPar ... 11310.html
PostPosted: Mon Oct 09, 2006 4:11 pm
That is the pic of my a-arm
PostPosted: Mon Oct 09, 2006 7:16 pm
Here is the picture of my rear boot installed after two year. No sign of the super glue coming loose Honda 53546-611-310 (its a automotive part number not ATV)
