It is currently Wed May 14, 2025 6:27 am
 Post subject: Not mine
PostPosted: Mon Apr 02, 2018 11:16 pm
I have seen this machine for sale before but it was many years ago.
The only things I don't like are that the front end is missing the tube for the triangle support for the front J arm mounts. Without this tube it will bend your J arm mounts very easily. In it's place he put some kind of basket. There are two small bolts in between the top and bottom J arm mounts but these would do absolutely nothing. Also it has no shock savers. Stock shocks and springs it looks like.
On a positive note I really really like that cage. He did an awesome job on it in the looks department. The problem in the safety department is that he forgot to add an angle tube from the top front hard point to the back roll bar. This would be a weak spot in a real hard roll over crash. I still like the look though.
Very nice seat and it is liquid cooled.
Appears to be the exact same pics as used years ago. Not up to date photos.
I think it is worth it if you can get it a bit cheaper. Located in Washington state near the capital Olympia.
https://seattle.craigslist.org/oly/snw/ ... 80581.html
 Post subject: Re: Not mine
PostPosted: Mon Apr 02, 2018 11:31 pm
That’s the same cage as nukem has. I’d love to have one. Or build one. Just need the connection pieces
PostPosted: Mon Apr 02, 2018 11:43 pm
Could be his.
PostPosted: Tue Apr 03, 2018 12:12 am
Not his that I know of. His cage is on the beastie.
Anyone could buy that cage years ago was an aftermarket cage
PostPosted: Tue Apr 03, 2018 12:51 am
Can't be Newecums...I don't see any bits of wool on it anywhere. :shock:
PostPosted: Tue Apr 03, 2018 12:57 am
Well we have definitely ruled out Nuecums.
PostPosted: Tue Apr 03, 2018 9:22 am
And the rear tires have at least 20 PSI :shock: :-)
