It is currently Wed May 14, 2025 3:40 am
PostPosted: Sat Apr 18, 2020 11:42 pm
All, I have a few things FS for FL350r. If you need any of this please let me know.
1. Engine. Has an original 78mm Honda OEM piston in it. This Engine has likely never been apart. I took the head off to examine and for sale pictures. Has an original head gasket too. Engine has 145psi compression with pull-rope. Comes with intake, reeds, stator, flywheel. Everything is tight; Very little movement of the piston indicating excellent serviceability cylinder-to-piston clearance. No shaft play and has good run-out. Perfect cylinder head dome. This WILL be an install-and-go Engine with LOTS of bores left. I will also include a NOS Honda OE Over-size 79mm ring-set - so if you find a 78.5 or a 79mm OE Honda NOS piston you'll be all set for the next top-end; plus ~4 Wiseco piston bores AFTER that. This Engine does NOT need to be rebuilt.
Engine is $950 shipped to lower 48 states.
2. OEM steel wheels. The tires are junk and will be dis-mounted. Original tires though. $50 for each front, and $75 for each rear, or $200 for all 4 rims. Shipping not included in the price.
3. Foot rubber pad. The 'upper' one. $50
4. Airbox lid. Nice shape. SOLD
Pictures are coming. Please PM/DM me with your request and zip code for shipping. Thank you
PostPosted: Sat Apr 18, 2020 11:48 pm
Pictures
PostPosted: Sat Apr 18, 2020 11:49 pm
More Pictures
PostPosted: Wed Apr 29, 2020 12:02 pm
Top end is sold.
Officially this Engine is now completely apart. Has an excellent condition crank. All parts are very nice.
Starter motor (( Internal Combustion Engine ? )) $80
Stator $75
Flywheel $50
Starter pulley $40
Starter gear $30
Reed cage $50
Front Foot pad $40
Airbox lid SOLD
Crankshaft SOLD
Cases SOLD
Balance shaft SOLD
Balance gears $40
Crank collar $20
Crank Front cover $30
PostPosted: Wed Apr 29, 2020 7:21 pm
Pictures
PostPosted: Thu Apr 30, 2020 3:26 pm
Sold the crank, cases, balance shaft. Updated the listing with items SOLD and still available. Mainly have the MAG side parts, rear cover, gears, starter etc.
PostPosted: Wed May 06, 2020 8:38 pm
Just checking.
Is the Engine available. My buddy was looking for a complete & stock motor (( Internal Combustion Engine ? ))
Thanks.
PostPosted: Sat May 09, 2020 5:22 pm
Majority of the Engine has been sold. What’s left, everything on the flywheel side. Also the rear cover and an excellent shape crank collar.
PostPosted: Sat May 16, 2020 11:34 am
Here is what I have left at this moment
