It is currently Sun May 18, 2025 10:00 pm
 Post subject: New to the forum
PostPosted: Tue Jul 02, 2019 10:10 am
Hello everyone, just purchased my first Fl350r last week. I've been scanning the net for things I had questions on and most of the time ended up finding the answer on these forums, so I thought I'd join. Cheers
 Post subject: Re: New to the forum
PostPosted: Tue Jul 02, 2019 12:29 pm
Welcome.
Give us some time there are a ton of smart people here that will chime in.
PostPosted: Tue Jul 02, 2019 11:57 pm
PostPosted: Fri Jul 05, 2019 3:58 pm
Welcome new guy.
This site is slow now but has more info than ANY other site.
I see you need to do some work there.
It has stock rear springs -- they are WAY to stiff. You need to order new springs.
I see sun faded wrist restraints and seat belts -- they need to be replaced.
My list of things to check on an oddy when you are doing an Engine job or bought one
Vent mod threads:
viewtopic.php?f=1&t=6309&hilit=no+case+modification
viewtopic.php?f=1&t=17606&hilit=vent+mod
viewtopic.php?f=1&t=18016&start=25
5) Engine must pass pressure AND vacuum test - if it doesn't don't even start it, find the leak. I use 10psi max pressure and 10in vacuum in my tests and it must hold for half hour minimum.
10) Check the wheel bearings.
14) Must build shock savers. viewtopic.php?f=1&t=15745&hilit=shock+saver+chain
15) Replace the rear springs with 155lbs units. Stock ones are way to stiff. https://www.summitracing.com/int/search ... 0.188.0160 http://www.naake.com/store/1.88-id
19) DO NOT rev the pizz out your machine while it’s just sitting there. The transmission is a splash lube system so this means it gets NO LUBE unless you are moving. There are several threads on blown AB bearings in the transmission. If you blow your AB you’re done, no parts available anymore.
20) You can get a free pdf manual here: https://oddatv.com/fl250-fl350-factory-manuals/
You can find all this info and parts books, serial numbers, etc in this thread: viewtopic.php?f=2&t=18393
PostPosted: Fri Jul 05, 2019 10:45 pm
Wow, thanks for the info. After looking it over I have found these things already. 1 Front bushings are shot 2 Brakes are almost non existent 3 Parking Brake doesn't work 4 Tank is in great shape 5 Needs tires and rims all the way around 6 Needs right side mirror 7 Tie rods are not so great 8 Rear suspension might as well be a solid axle with the way the rear shocks feel 9 Rear brake light needs to be wired up 10 Has the original tool box and tools 11 Front bumper is bent and welded 12 Looks like the po wired up a tether switch on the steering wheel?
PostPosted: Fri Jul 05, 2019 10:49 pm
Also was looking at either getting a liquid cooled head and radiator with fan or doing a rotax motor (( Internal Combustion Engine ? )) swap. Not too sure about the motor (( Internal Combustion Engine ? )) swap because I plan on registering it and riding trails here in Wisconsin
PostPosted: Sat Jul 06, 2019 12:27 pm
In my opinion, do all the things on your list first. Get the 350 running correctly. They make a ton of power when running right. You may decide shelling $2000 for a Rotax isn't really worth it.
Water cooled is always a good idea though.
PostPosted: Sat Oct 05, 2019 10:32 pm
Does anybody have a lead on where I can get j arm bushings? It appears that all four of them have seen better days.
PostPosted: Sat Oct 05, 2019 10:43 pm
Look on eBay, speed chaser sells a set that he makes and on one of the ody/pilot forums I noticed he just posted about adding some to his store.
https://www.ebay.com/itm/FL350-Honda-od ... SwG4ZdlQsd
Bob
PostPosted: Sun Oct 06, 2019 12:45 am
Perfect, thank you
PostPosted: Sun Oct 06, 2019 1:21 am
How is your project coming along? Any updates or pics?
PostPosted: Wed Oct 09, 2019 10:13 am
Project is coming along at a snail's pace, I've been working 7 days a week since march and haven't had a whole lot of time to put into the fl350. I did however finish everything but cosmetics on my 200x and got the 350x running lol
PostPosted: Sat Oct 12, 2019 5:40 am
Have a bushing kit, Reed gaskets, and base gasket on the way thanks to speed chaser. Cheers
PostPosted: Wed Feb 19, 2020 3:13 pm
i bought the front disc brake kit from Farr offroads but lost instructions does anybody know how to get hold of him
PostPosted: Wed Feb 19, 2020 4:30 pm
he is still selling stuff from ebay, I checked his website but did not see his number or email address, he is also a member of this forum.
PostPosted: Mon May 25, 2020 2:11 am
So I finally started working on my odyssey recently, sold my 85 350x and 86 200x three wheelers for funding. I have contacted methodical and plan on doing his liquid cooled jacked and head system instead of going with the rotax Engine swap. Have a bunch of parts showing up in the next few weeks and I plan on pulling the motor (( Internal Combustion Engine ? )) this week and rebuilding the bottom end. I also have a 3/8" dewalt impact on the way to make things easier with disassembling the case. Along with the two puller tools and bearing puller tool I have on the way, do I need any other specialty tools for the rebuild? Thanks
PostPosted: Mon May 25, 2020 2:14 am
Oh yeah, I would also like to buy rims and tires as the originals are pretty beat up. I was thinking of going with a taller tire front and back for extra ground clearance. My question with that is if I go with taller tires am I going to have to change springs and weights in my clutch to make up for the added power it is going to take to spin them?
PostPosted: Wed Jul 22, 2020 1:51 pm
Got some work done yesterday and today, much more to come b4 she is ready to rock.
PostPosted: Wed Jul 22, 2020 6:18 pm
a little JB weld, that piston will be good as new LOL
hard to believe it ran long enough to do all that damage
