It is currently Thu May 15, 2025 1:07 pm
 Post subject: pilot specs
PostPosted: Wed Dec 20, 2006 6:38 pm
anyone know what the specs of a pilot are- length,width, and wheelbase is mainly what im after. i plan on building something very similar. im going to take a 660 raptor and turn it into a buggy. but i want to keep it small so i can still ride on atv trails. thanks
ron
PostPosted: Thu Dec 21, 2006 10:20 pm
Hi Ron, heres alittle info for you-
Length: 96.4 inches
Width: 50.5 inches
Height: 57.2 inches
Wheelbase: 62.2 inches
Ground Clearance: 9.3 inches
Brakes: Front, Dual Hydraulic. Rear, Single Hydraulic
Dry Weight: 1989 - 592.5 1990 - 605.0 pounds
Engine: Water Cooled, 397.1cc, 2 Stroke, Single Cylinder
Bore and Stroke: 80mm x 79mm
Compression: 6:2.1
Carburetor: 32mm Piston value, Reed Valve
Coolant Capacity: 2.16 quarts
PostPosted: Thu Dec 21, 2006 10:22 pm
Heres for a fl350f in case you wanted to compare the 2 RON-
FL-350R Specifications
Engine: Air Cooled, 329.1cc, 2 Stroke, Single Cylinder
Bore and Stroke: 78.5mm x 68mm
Ignition: Capacitor Discharge, 17.0dg BTDC at 2,000rpm
Sparkplug: NGK BR9ES. 0.7 to 0.8mm
Starter: 12V Electric and Pull Start, Recoil Type
Electrical: 12V-160 W @5,000 rpm
Clutch: Automatic
Transmission: V-Belt Torque Converter with Forward, Neutral and Reverse via Stick Shift in Cockpit
Suspension: 4 Wheel Independent Suspension
Length: 85.0 inches
Width: 58.1 inches
Height: 60.6 inches
Wheelbase: 56.5 inches
Ground Clearance: 8.3 inches
Fuel Capacity: 3.8 Gallons at 20 to 1 (Now 32 to1)
Tires: (F) 21 x 7.0 - 10 (R) 24 x 11 - 10
Rim Bolt Pattern: 10x5 4/110 (F) 10x8 4/130 (R)
Dry Weight: 602.0 pounds
PostPosted: Fri Dec 22, 2006 10:09 am
thanks for the info guys. that helps a lot. any idea how much power they made compared to a 660 raptor? and do u know where i can search them so i can really look at one? i just want a few more ideas.
thanx ron
PostPosted: Fri Dec 22, 2006 11:53 am
I'd really love to see a FL400 pilot that is 50.5" wide...
Its supposed to be 60.5"...
IT IS A TYPO...
This little typo has caused a great deal of GRIEF...
It has been posted on boards since day one and beacuse of it at least two areas that I used to ride in are now have gates at 50" to keep the bigger toys out...
National Parks also adopted that 50" width limit :-(
