It is currently Mon May 19, 2025 8:48 pm
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Jun 23, 2007 12:28 pm
The longer ones are distance collars they go between the two bearings inner race so when you tighten the BIG nut your not putting stress on the ball bearings, the vertical line you see looks like a weld on a seam I assume they used seam pipe to make the collars, the length is critical it sets the exact distance if the ends are not damaged or worn down, or any damage that would affect the length use them again.
The short collars are a spacer the grooves on the outside are where the seal rides it is exposed to the elements so wear and rust easily, we need some of these fabricated out of stainless steel tubing they would last forever.. If worn too much they will allow dirt, water etc. past, you have seen whats inside.
PostPosted: Mon Jun 25, 2007 8:21 pm
a little scrubbing and banging and this is where I stand so far,
File comment: bolt comparison. microscope pics to follow once I figure IT out.....
File comment: Still need to squeeze more grease in before its ride ready.
File comment: ditto
File comment: These are what I need to cut out in order to get the stock tie rods to pass. This is the end of the bump steeer kit.
File comment: must not forget cotter pins.....
File comment: painted the rusty areas.....
PostPosted: Mon Jun 25, 2007 9:26 pm
Take a hack saw and cut them off bewteen the round part and the frame, they put a HUGE GOB of weld in their lol
PostPosted: Tue Jun 26, 2007 11:26 am
those look familiar!!! what you are cutting off to return yto stock!!!
did chucklenuts at aftershot motorspurts copy tis for his long travel kit???
PostPosted: Tue Jun 26, 2007 11:35 am
Yeah there is way too much play in the steering on this setup.
I knew it when I bought it. With maintenance the steering sures up. But, it was more than just the rack that needed servicing.
And as we looked into it the play was additive from the ball joints to steering wheel.
Started down the path of replacing the ball joints. Then Hare was nice enough to score some parts for me.
In the northeast here the trails are tight and I need a tighter turning radius without having the lite up the rear tires to turn around. I decided to swap out the LT A Arms and while I'm at it replace the steering back to Honda.
I liked the LT and all. But, I need to be more practical.
I would have just removed the clips and pulled the rack. But then the mounts are in the way of the tie rods etc.
I have all the parts. Except for brake lines. I have braided lines and they were damaged by my carelessness.
Once I get the rack exposed and removed I will order new braided lines sized to fit.
PostPosted: Tue Jun 26, 2007 11:54 am
keep these parts for me if you don't mind.... just for some research stuff... make some good msrmt on fitting that you will cut off!!! LOL
PostPosted: Tue Jun 26, 2007 1:04 pm
rack & pinion steering??? interesting...
How did this handle and steer??? were you happy with it??? except for your width concerns???
PostPosted: Tue Jun 26, 2007 1:27 pm
Take all kinds of pics as you remove it.
PostPosted: Tue Jun 26, 2007 1:39 pm
OK I will keep taking pics.
Right now I need to raise the front end way up to make it easier to work on....
Without it falling and crushing me or the kids.
I have very few hours of riding with this machine. My second name is Squarerim due to all the flats I've gotten and the fact I've squared a rim. I found the Powerblock clutch was not good for me. It blew up anyways. And now I'm a stock clutch user. I don't need the extra torque that would lift the front end up on me. I recall a PA ride where I was stuck in a gully and the front end would lift as I tried to get going. I was trying to steer but as the weight let off the front tires I just kept getting deeper into trouble. Those teens sure had fun watching me..... Thanks Guys for helping!!
But I liked it. I could get the steering to lock if I was not careful though.
PilotNut maybe a better person to comment. I bought this from him.
Once I get this back and operating I'll have a better opinion.
PostPosted: Tue Jun 26, 2007 3:33 pm
I see your point on the front end lift... I am a control freak... driving wise I mean... if your tires up front are light to airborn there is no control...
minus the r & bp steering this looks alot like my new setup... I need to explore this more... I am sure you will like the stock setup with the works shocks... did you get them set up to litespeed's spec's
PostPosted: Tue Jun 26, 2007 4:00 pm
Well. My Works shocks are on the Odyssey FL350.
I had Works for the LT setup. And for now I'm leaving them alone and will include with the pile of LT parts.
I am considering new works OR over haul these. But, not until I have this running again and I've had a chance to ride again. Once the CC bill is gone then I can consider more parts.... But, wife wants/needs a new SUV/car.
Hmm I got a thought will FL350 Shocks fit a Pilot? I have Works ready to go for my second FL350 project.
PostPosted: Sun Jul 01, 2007 3:38 pm
This weekend I got to a lot of the Pilot work.
Removed the front bumper in order to remove the skid plate. Easier said than done.
Washed sanded and painted many parts.
Got into the steering and after a couple hours of persuasion I removed the rack steering.
Next steps will be to replace the steering rod. Its hard to tell wahts stock and whats not.
This is a lot more work than I was expecting. But well worth the fun.
File comment: naked front
File comment: skid plat front mounting points
File comment: bumper mounts
File comment: soem rust and lots of chips. I wonderif this is powder coated and chipping?
PostPosted: Sun Jul 01, 2007 3:45 pm
and some more
File comment: fresh coat of paint.
File comment: skid plate
File comment: left rear mount
File comment: right rear
File comment: Mid mount and what a pain it is to get to
File comment: inside of steering
File comment: Front brakes T fitting
PostPosted: Sun Jul 01, 2007 3:47 pm
and some more
File comment: Stilleto
File comment: end of steering shaft so far...
File comment: bottom of seat where the lower seat belts bolt together. I think this needs a change.
File comment: cut off :)
PostPosted: Sun Jul 01, 2007 4:49 pm
yep looks to me like Steve copied this set up, and he just couldn't find the stilito or couldn't afford it... Hell he didn't even bother to search for a 10mm hiem So a guy wouldn't have to drill out the hard steering knuckle... Which by they way I am in need of a cherry knuckle if anyone has laying around... I think I will use the hiems I have when I get my stainless links remade!!! I don't like mine wearing so much with 20 minutes of driving on them...
PostPosted: Sun Jul 01, 2007 4:56 pm
PostPosted: Sun Jul 01, 2007 5:37 pm
He did a piss poor job of copying it, those bungs you see are steel tubing with nylon bushings NOT STEEL ON STEEL I forget exactly the clearance you would have to call hi performance ATV guy and ask but I think it was .060 clearance.
Nylon was used because it was no afterthought, its soft so it CANT JAM UP the material is too soft for it to dig in, its also design to wear out the bushing not the tie rod...
IMO metal on metal in this environment is just plain dumb.
I know someone that can make the nylon bushings for you if you change your design
PostPosted: Sun Jul 01, 2007 5:46 pm
Don't they make nylon lined heims?
Was pretty sure they did, may not be thick enough nylon though.
PostPosted: Sun Jul 01, 2007 5:55 pm
Yup the liner is between the outer ball not the inside, I never seen a hiem used like this before where lateral loads were applied or sliding force was implied, I am not sold on the idea, even with clearance it looks like it could lock up under the wrong conditions, I am all for inventing new stuff but this looks dangerous to me, after beating my Pilot all these years http://pilotodyssey.com/hosertrip.htm and seeing the underside of my Pilot and all the dings and dents from the beating I would not leave my shop with a setup like that.
Their is already BETTER ideas engineered out their, no need to reinvent the wheel, look at any radio controlled car or truck suspension and steering, go to walmart and start looking under the cars in the parking lot at their steering, skip the front wheel drive cars.
Where is Lee I bet he has a better idea, I am a suspension and steering moron.
You can get some wood and trial and error your setup, prototype real fas with wood, if it works ok then duplicate out of metal.
The ATV Racing bump steer is an example but I don't like adding all the extra hiem joints to the tierods soon as they start to wear all that wear adds up fas to lose steering, its a maintenance nightmare but that's better than a tie rod locked up in a hiem.
PostPosted: Sun Jul 01, 2007 6:07 pm
Yeah, you're right, that was a stupid thought, I have a box of the nylon lined ones in the garage for the buggy links.
PostPosted: Fri Jul 06, 2007 8:00 pm
Tapped the steering shaft out. Was a lot easier than the manual will tell.
getting closer...
File comment: new shaft thank you Mud! new coat of paint
File comment: the steering wheel end
PostPosted: Sun Jul 29, 2007 1:47 pm
Make note. Don't paint the shaft as much as I did. Its a bear to drive the shaft up throught he lower bushing.
From what I can tell the steering shaft column on my Pilot was cut shorter.
As stock steering shaft is too long to fit correctly. I think the top was cut to allow for more arm length maybe?
I do know the rack's steering rod was cut and a new fitting was added. Look slike a stock shaft modified.
In any case I think I will just cut a piece of pipe to make an upper collar. Other wise the shaft will creep downband it screws up the tie rod travel.
File comment: too much sticking out.
File comment: lower end up flush to the O ring, bushing and washer.
File comment: It drops down like this and needs to be hammered back up without an upper collar to be added.
PostPosted: Sun Jul 29, 2007 2:12 pm
MORE
But with the macro lens on the camera
PostPosted: Sun Jul 29, 2007 2:13 pm
some more
PostPosted: Sun Jul 29, 2007 4:31 pm
The consensus is that the lower end was chopped.
I hammered the shaft down and made the steering wheel fit right.
I will either replace the steering column or just add a pipe to compensate.
In either case I need to bang the shaft out and start again.
No Worry this is what it is all about!
Bob
