It is currently Wed May 14, 2025 10:56 pm
PostPosted: Sat Aug 18, 2007 12:54 am
As the title says. I am looking for the proper way to make sure the float level is set right on this carb. I have tried searching the net and found no specs on this carb that tell me what I need. Any idea on this or a website with the info? Thanx Bill
PostPosted: Mon Aug 20, 2007 11:52 am
Have you got your answer to this yet? I don't really mess with Mikuni carbs but can probably help you find your answer.
 Post subject: Nope not yet
PostPosted: Mon Aug 20, 2007 9:35 pm
I have not found the true answer yet. I have done about three hours of searching and all I found was a couple sellers of this unit. There is a little info I found on other Mikuni's but they are some special carb for Hardley-a-Davidson. I would like to know what the maker recommends. But I have been unsuccessful in finding thier specs. Thanx Bill
PostPosted: Mon Aug 20, 2007 10:08 pm
Should be 19mm...Baz
http://www.sudco.com/cat32/35-41.pdf
 Post subject: Thanx so much!
PostPosted: Tue Aug 21, 2007 12:55 am
Well your search defiantly made more progress than mine ever did. Its the first time I have seen that much info on these carbs in one place. Thanx X10!! It does state to set the float between 17mm and 19mm. Guess I will have to guestimate (or go 18mm). I am going to favor a richer setting as it has been doing the lean out thing on me. I was looking at the "Power Jet" they offer on there for extended full throttle runs. Looks like a dial a jet type add on?? But jets you change instead of a dial you spin. I do not suppose anyones got any expierience with that mod? (Power jet) ? Thanx for the link. Bill
PostPosted: Tue Aug 21, 2007 2:31 am
The other tip I learned from the dealer(Ian Williams Tuning) and my mechanic, is the same as for the others, which is to set the Float Plate parallel with the carb body.
 Post subject: Re: Thanx so much!
PostPosted: Tue Aug 21, 2007 6:32 am
I think your jetting problems are more Engine design than carb issues...
 Post subject: I am afraid your right.
PostPosted: Tue Aug 21, 2007 11:45 am
I am afraid that you may be right on with the other Engine issues causing most of my issues. I am hoping to have these cornered this time. I do have a question that's sort of related. What will to much squish area cause in a motor (( Internal Combustion Engine ? ))? Before I think I had to little and If I went to far here I can reduce it. But I am curious as to what to much area there can cause. Thanx Bill
PostPosted: Tue Aug 21, 2007 12:31 pm
I have forget most the details about your Engine I wish we would have documented them here but I think you need to correct the CR (compression ratio) problem by re chambering the head or replacing the head rather than trying to correct with spacers.
PostPosted: Tue Aug 21, 2007 7:40 pm
Can you measure from the top of your cylinder to the top of your exhaust port opening at its highest point?
 Post subject: Juggs and stuff
PostPosted: Wed Aug 22, 2007 9:47 pm
The two stock jugs that I had ported have not had the head surface milled down I do not believe. They both measure 1.64 inch. (ones 1.644 and the other 1.645) <PCP port jobs) The other jug that was on the machine when I got it is 1.66 inch to the top of the exhaust port. <(PMR port job.)
