It is currently Sun May 18, 2025 7:09 pm
PostPosted: Tue Nov 27, 2007 5:38 pm
I thought I would post some pictures of my project in progress, pilot with rotax 793 Engine with RER, subaru impreza limited slip diff and fiddle/ cutter brakes. I will post more pictures if there is any interest.
PostPosted: Tue Nov 27, 2007 5:42 pm
Yes their is a interest please post more pics..
PostPosted: Tue Nov 27, 2007 5:58 pm
More photos.
PostPosted: Tue Nov 27, 2007 6:07 pm
A rough and very short video of first drive http://www.porkolt.com/personal/honda/v ... 18997.html
PostPosted: Tue Nov 27, 2007 6:12 pm
Sorry try this http://www.porkolt.com/personal/honda/v ... 18997.html
PostPosted: Tue Nov 27, 2007 8:12 pm
Link no workie here
PostPosted: Tue Nov 27, 2007 9:23 pm
Jesus Leegb I saw your progress on mini-buggy. Very nice work =) Seems to haul ass from the video. Hows the speed with the extra weight of the subuaru diff?
PostPosted: Wed Nov 28, 2007 1:02 am
holly crap that is freakin insane mate :O . how much power that motor (( Internal Combustion Engine ? )) got? it looks like its got some serious grunt in that video. well done
josh
PostPosted: Wed Nov 28, 2007 2:47 am
Ody_Stable wrote:
Link no workie here
The link seems a bit hit and miss, Try putting "porkolt honda pilot" in serch Engine google, that worked for me.
PostPosted: Wed Nov 28, 2007 2:53 am
There is no extra weight over a standard pilot, I am not using the pilot transmission and the rotax motor (( Internal Combustion Engine ? )) is light, no balance shaft, just the bear minimum. The reverse is very light just a few extra wires a button and maybe a micro chip :-) I do not understand why more people no not use engines with RER.
PostPosted: Wed Nov 28, 2007 2:56 am
josh
I am told the Engine has 138 bhp? It feels fast :shock: I need the cutter brakes to steer because the front tyres bearly touch the ground under acceleration.
PostPosted: Wed Nov 28, 2007 3:04 am
Pull some wicked wheelie donuts man!! lol Have you thought of weighing down the front end?
Or better yet... put some ski's on it!!! LOL a Dune/Snow/Land DuneBuggy!
PostPosted: Wed Nov 28, 2007 5:06 am
138 geeez. why bother even having wheels on the front hahaha. wheelie donuts, do a backflip hahaha how does the rverse work?
cheers. josh
PostPosted: Wed Nov 28, 2007 2:01 pm
cheers. josh[/quote
There are 2 pickups to tell it when to spark, basically it switches over to the other pick up, the Engine backfires and runs in the opposite direction, The 2 stroke oil pump, water pump and cvt drive are designed to work with this type of Engine. It has a lower rev limit in reverse.
PostPosted: Wed Nov 28, 2007 2:20 pm
cheers. josh[/quote
What is the Engine out of?
A buddy of mine had a sled with the reversing Engine worked pretty slick.
PostPosted: Wed Nov 28, 2007 3:12 pm
cheers. josh[/quote
The Engine is the same as a ski doo 800 but I bought 2 used engines with carbs CDI (Capacitor Discharge Ignition)/ecu,s exhausts and everything else to run them, and 2 brand new spare engines, they were used in hovercraft in the James bond film die another day but were taken out of the hovercraft before they were blown up.
I have sold the 2 new engines but still have the second used Engine, If anyone has clutches to fit 02 on ski doo 800 I would be interested.
PostPosted: Wed Nov 28, 2007 3:25 pm
some pictures of fiddle/ cutter brakes, discs mounted to inner cv cup.
PostPosted: Sun Dec 09, 2007 1:33 pm
Does anyone have a wireing diagram for an 89 pilot, my manual has the last few pages missing.
Thanks Lee.
PostPosted: Sun Dec 09, 2007 4:06 pm
Thanks for that Ody-stable, I can try to get it all wired up now.
PostPosted: Sun Dec 09, 2007 5:58 pm
Has anyone had experiance of wiring a rotax Engine in to a pilot chassis.
I am not sure if I should use the pilot regulator which seems to have 6 wires going to it or use one from a ski doo which has 5 wires, and what to do with the extra wire or terminal, and any other tips for the wiring.
Also I have found that the original pilot throttle lever seems very heavy, probably because I am controlling 2 carbs and an oil pump, the length of the stroke seems fine so I can not alter the ratio. I wondered if I could use a kind of "Fly by wire" kind of set up from another vehicle?
PostPosted: Sun Dec 09, 2007 7:26 pm
I put a 440 ROTAX rotary in my Pilot but I used a single 38mm carb off a water craft so the throttle is soft and easy as it was stock.
I have heard of guys cutting a few coils off the springs to make it softer but you have to make sure your not putting yourself into a situation where the throttle can stick, I seen a few other sled conversions where they used a foot throttle..
For the regulator I used one made for my stator setup, mine only has 2 wires coming from the charge coil so I used a small 2 wire regulator rectifier at first then later upgraded to a larger one I got from DC that was for a Harkey Davison motorcycle. Info here http://pilotodyssey.com/PO/viewtopic.ph ... =regulator
If you can post a copy of your wiring diagram for the sled our electrical gurus here can probably work out a solution.. Heck you might be able to use the stock Pilot regulator rectifier.
PostPosted: Sat Jan 05, 2008 3:03 pm
A short video, wet road. http://uk.youtube.com/watch?v=_twG7JYTy0w
PostPosted: Thu Feb 14, 2008 6:41 pm
I got out on my pilot in mid wales on tuesday, the kid on the bike is my son on his crf 150.
http://uk.youtube.com/watch?v=OSUtjXdk-7s
