It is currently Mon May 19, 2025 4:47 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 13, 2008 6:26 pm
New crank gets washed before oiled and installed, all new cranks are nasty dirty even though they are new.
PostPosted: Sun Jan 13, 2008 6:27 pm
Everything gets oiled before and during assembly.
PostPosted: Sun Jan 13, 2008 6:28 pm
Home made tools required to assemble the Engine
PostPosted: Sun Jan 13, 2008 6:29 pm
Once the puller is assembled and ready to pull the crank into the bearing the crank is oiled so no galling can occur.
PostPosted: Sun Jan 13, 2008 6:30 pm
Once the crank is pulled into the clutch side of the crank case its time to prep the gasket and install the dowel pins
PostPosted: Sun Jan 13, 2008 6:32 pm
See the two dowel pins?
I first install them then take 2 stroke oil and coat the cases
PostPosted: Sun Jan 13, 2008 6:33 pm
Once oiled install the gasket into the oil
PostPosted: Sun Jan 13, 2008 6:34 pm
Then oil the gasket surface on the other case.
PostPosted: Sun Jan 13, 2008 6:35 pm
Take the gasket off the other case and lay it in the oil
The flip side, use your fingers make sure both sides of the gasket is well oiled.
PostPosted: Sun Jan 13, 2008 6:37 pm
Put the gasket back on the dowels now its well oiled on both sides and the gasket surfaces are well oiled its time to install the other case.
PostPosted: Sun Jan 13, 2008 6:39 pm
Slide the other case on a little ways gravity will work against you here and the case will self level like seen in the pics, I use TWO of the longest case screws to hold the cases and line them up whilst using the case puller to pull the crank in the bearing, sorta like the rubber bands keep the rod in place.
PostPosted: Sun Jan 13, 2008 6:40 pm
Ready to install the crank puller.
PostPosted: Sun Jan 13, 2008 6:42 pm
Now is a good time to set the Engine on a flat surface and not a rag you don't want something pinched between the cases :shock:
As I start to pull the crank into the bearing the dowels are well oiled
PostPosted: Sun Jan 13, 2008 6:45 pm
Pulled together.
NEVER even think of trying to pull the cases together using the case bolts, if you did your putting thrust loads on the balls of the bearings damaging them AGAIN the TWO bolts you seen in the pics were only to help line up the cases until they were close enough together the dowel pins took over and lined up the cases.
When using 2 of the long bolts their is not even and reason for the heads of the bolts to touch the cases.
PostPosted: Sun Jan 13, 2008 6:46 pm
People probably wonder why their is oil stains on the outside of their Engine its from assembly :-)
PostPosted: Sun Jan 13, 2008 6:47 pm
Balancer cover gets installed, mating surfaces are oiled first.
Bearing is pre oiled as well.
PostPosted: Sun Jan 13, 2008 6:48 pm
Case bolts are installed.
Other balancer bearing is pre oiled
PostPosted: Sun Jan 13, 2008 6:50 pm
Balancer installed, the TWO bolts and tabs that retain the balancer have to be clean and thread locker applied to the threads.
PostPosted: Sun Jan 13, 2008 6:52 pm
I am missing pics here but the O rings get installed on the crank then the crank seal then the gear that drives the balancer, the timing marks MUST be lined up as seen in the service manual...
The dowl pins are then installed and the gasket surfaces oiled just like the crank cases were.
PostPosted: Sun Jan 13, 2008 6:54 pm
The seal behind the recoil is greased before installing, the end of the crank gets thread locker so the nut cant fall off.
The clutch side crank seal is greased and installed using the hoser seal installer tool
PostPosted: Sun Jan 13, 2008 6:56 pm
Once assembled crank it over a few times and feel the extra drag the balancer and seals have.
Plenty of oil inside from assembly..
