It is currently Tue May 13, 2025 8:14 am
PostPosted: Mon Apr 07, 2008 3:46 pm
they are made for racing and not trail riding. http://www.hoosiertire.com/specmisc.htm#ATV
PostPosted: Mon Apr 07, 2008 3:52 pm
this is a good front tread pattern allot of sprintcars and stockcars run these, they also come in different compounds.
File comment: good for front
PostPosted: Mon Apr 07, 2008 3:57 pm
rear tires.
File comment: wet track more grooves (clean outs for mud)
File comment: dry track less grooves = more rubber on track
PostPosted: Mon Apr 07, 2008 4:18 pm
here is another company they only offer one tread pattern though, http://www.americanraceronline.com/ATV- ... quads.html
PostPosted: Mon Apr 07, 2008 4:26 pm
or even the larger companies are flattening out there front tires for better steering, http://www.maxxis.com/products/atv/prod ... asp?id=210
PostPosted: Tue Apr 08, 2008 2:31 am
Thanks again for going to the trouble of posting info. :-)
I don't think either of those tyres would handle the Sticky n greasy dog-bog type clay here,they would just be plastered up all smooth and even.
I need a more aggressive tyre for the front with sideways bite into the turns.
This is what I have found so far.
The X-Drive(like the razors) have little bite.
Changed to the F1 and it was noticeably better,due to the aggressive shape,angle of the tread knobs.
I think I'll be getting the next larger size up F1's for the front's,to gain a bigger footprint.Will take note and report back results.On the rears I was using the Dirt Devils,good mix-balance- of grip and traction break for the rear end steering.
File comment: These I found to have little or less grip than others.
File comment: These F1's made a def diff in the front grip dept and aid the steering affect.
