It is currently Wed May 14, 2025 12:14 pm
PostPosted: Tue Jun 10, 2008 11:31 am
Un F@#*NG BELEIVABLE!
Pulled the silencer - extremely loud but same issue
Filter on / off - same issue
So taking what Hoser said I double checked the grey wire - no connection and capped to prevent any grounding. Figure to test the circuit I would connect the ground it to ensure it worked. AND IT REVS UP!!!!?????
The Honda wiring diagram clearly shows it as ground to complete the circuit and limit rpm. My FL350 had it disconneted and capped. (No connection). Talked to an ex MC mechanic at one time - told me to make sure it was not connected.
But for some reason shorting it to ground allows it to rev up now.
PostPosted: Tue Jun 10, 2008 12:12 pm
That wire is usually hooked to the trans, when your in reverse the switch breaks the path to ground so it wont rev?
PostPosted: Tue Jun 10, 2008 12:55 pm
sweet....now your ready to race?
PostPosted: Tue Jun 10, 2008 1:31 pm
Congrats! I'm looking forward to racing with you. See you Saturday at Lake Elsinore?
PostPosted: Tue Jun 10, 2008 2:36 pm
Glad to hear its up and runnig for you.
 Post subject: FIRST RUN!
PostPosted: Fri Jun 13, 2008 1:19 pm
After too many 100am nites, it just went for it is first run.
HOLY XXXX!!!!!
Even with the carb not dialed in and the clutch coming in too late it is un ----- believable.
The whoop section - did not even feel it. The big jump (which is 7'+) - landed like you were on a couch.
Only a few minor issues to fix for Sat nite - and one big one - will full power it will lift the front wheels. Sounds cool, but it will not turn if you are on the gas. Stabbing the brakes will get it to turn NOW. May have to add 20# of lead over the front end.
31 hours to go......
 Post subject: Re: FIRST RUN!
PostPosted: Fri Jun 13, 2008 1:43 pm
HOLY XXXX!!!!!
don't forget pics and video :-)
Also put a oiled foam pre filter over that K&N before jetting.
PostPosted: Mon Jun 16, 2008 12:12 am
I hope your weekend went well!!!
PostPosted: Mon Jul 14, 2008 11:20 pm
WOW!!! That car is fast. I tried my hardest to keep up and I just couldn't. It looked awsome 5 feet in the air in front of me also. Way to go Ken.
PostPosted: Sun Jul 20, 2008 10:40 pm
That last race was a blast!
However we found a few things wrong.
First the clutch we set up for Elsinore - up shifted way too soon for the tight track. Gonna build a HOSER HOLDER to make it easier to tune the PowerBloc clutch
Second the belt is wrong - too short, drive clutch never got more than 60% belt travel.
Front shocks are too soft - will change fluid and add some ressys
Front car tires zuck - will get some quad tires for it.
Now for the very cool part! Bob with Extreme Baja Kart sent me a scan of a magazine article from ATV Sport back in 1988 profiling the H&R cars. As soon as I can shrink it (the pages are 8meg each) I will post them
BUT, PHOTOS are now on POSTED! Vist www.bluecoyoteracing.com and click on Stadium Lite for lots of photos!
Next race - Aug 2 - Podium Productions - Milestone MX Park - Riverside CA
Below is a teaser...
PostPosted: Mon Jul 21, 2008 10:01 pm
Lookn good ken cant wait til the next race
