It is currently Sun May 18, 2025 2:27 am
PostPosted: Mon Jul 28, 2008 4:59 pm
I'm running a beard super seat in my pilot without any hieght issues with my helmet with the stock cage. I would sell your current seat and buy a beard super seat. I got mine used for 80 bucks. It is in like new shape. If you search race-dezert.com I bet you could find one cheap. It will save money on tube and time on redoing the whole cage
PostPosted: Mon Jul 28, 2008 6:02 pm
I have never seen the extra padding on a seat??? You could always put on a healthy 40 pounds by staying at the dinner table longer???
Adding the 4.5 inches won't give you enough head room if you are bumping your noggin with out a helmet already...
Talk to Randy at Odysalvage he has a seat that fits into the stock ODY and Pilot already jigged with tabs... maybe it will save you some time???
I am using the seat and like it...
PostPosted: Mon Jul 28, 2008 8:03 pm
Akpilot wrote:
Finally got my roll cage tube bent!! What a hassle, after about 3 months waiting for the race cars guy to bend up the second hoop I took it to 3 others, the first two kinked the tube and the last one left some 1/4" wrinkles, pretty bad but I have little options. The race car builder had what I thought was a JD2 bender, and so did the last guy, but the following bar was different. The car guy had a trinagle following shoe instead of just a rectangle shoe. The triangle had two holders like the normal JD2 but on the top it had a nut welded to it. As he bent the tube he would keep tightening a bolt that forced the shoe into the die. His did not wrinkle the .058 co-molly, but deformed it very slightly. What do you guys use for bending 4130? I kindof burned my bridge to the race car guy or I'd go over and get the model of the bender. At the time I just took it for granted it was a JD2 bender.
Now that I on to the roll cage, I'm having some head room issues. With the wider lower frame rails I was able to squeze the Pilot seat I purchased for the FL800 into this frame. I made the seat frame even with the frame rails, but with the added height of the suspension seat I can hit my head on the stock roll bars without a helmet. Therefore I need to raise the stock cage if I use a suspension seat. Also with the seat, it leaves the top frame bar about thigh level giving the feeling your sitting on the frame instead of in the frame. I really want to use a suspension seat for cumfort and safety reasons.
What have you guys done with the suspension seats in your Pilots? Is my seat just wrong? It seams TOO thick. If I take out the lower cusion it is a lot better, maybe making a thinner cusion is in order. The cusion is only about half the problem tho. And what about head room clearance, what is concidered ok...6"?
Wayne
Suspension seats are NOT safer fact is when they compress they LOOSEN your harness, how would you like to be flipping and rolling with a LOOSE harness? Think about it if your seat will compress 3" then you have 3" slack between your shoulders and the harness, if the cheeks of your ass can compress 2" now you have 5" slack... Ever watch a professional racer get in his car/truck they keep pulling the harness down then a few min later pull on it again as the seat compresses, you have to have a limit strap under your seat to limit its travel to 2" for SODA and CORR races, I am sure others have it as well.
Bottom line is if your relying on a seat to save your back your in the wrong sport...
PostPosted: Mon Jul 28, 2008 9:24 pm
I have a old BEARD seat I bought off Ebay-I have never used it, it is in OK shape-I';ll donate it to your cause if you like-it is Gray.
PostPosted: Mon Jul 28, 2008 10:08 pm
Thanks for the offer Mud.... But maybe I'll have to rethink my suspension seat idea. Making the roll cage taller because of making the frame wider will look right. If I widen the rear 2" then I'll need to heighten it at least the same or it will look kinof short and squatty - if that is even a word :-).
I remember reading on the other Odyssey site about someone breaking a vertibrae from jumping too big and landing too flat. With the stock seat only your back compresses after suspension bottoms out. Therefore I bought into the fact that give in the seat is the way to go....Never thought about the seat belts. Nore for that matter do I strap in that tight to begin with. I use a 5 point harness and just snug it up, not "strap down".
So as I see it right now the question I need to ask myself is: Do I want the belts to become loose as I compress, or do I want the energy transferred into my back? Is this right?
"Bottom line is if your relying on a seat to save your back your in the wrong sport..."
I will tell you guys one thing... If I knew in advance that I or my kids could become paralized from these 20 year old toys, then yes I need to find something different. Not to say that I can become crippled rolling out of bed in the morning.
Wayne
PostPosted: Mon Jul 28, 2008 11:27 pm
Not to throw fuel on the fire, but you DON'T want a suspension seat older than 5 years old. Most reputable makers won't warrantee them past 5 years for a reason, the suspension (elastic straps) will start to show signs of age and cracking after 5 years.
Old seats are either harder (stiifer) than new or may break when you think you need it most.....
PostPosted: Tue Jul 29, 2008 12:37 am
My Corbeau seat had cotton rope for the suspension part and rotted within a year. I replaced it with nylon rope from homo-depot.
I believe different than Hoser on the suspension seat debate and I know it makes a big difference on the average riding trip. If your worried about the slack in the belt go to a 6 point harness.
Tom
PostPosted: Tue Jul 29, 2008 5:31 am
Tom
Slack is slack go with a 10 point harness it don't matter, maybe install a spider web to hold you and you get beat up by the roll cage, steering wheel, it will be like getting hit with a pillow case full of rocks haha.
This is a perfect example why sanction race bodies have rules and inspect before races...
Everybody has their own level of risk they accept, MANY people like to drink beer whilst they go hunting wabbits... I could care less what seat people use, I do make sure people understand their is a DANGER and greater RISK with using suspension seats, the funny part is when people call them "safer" then try to argue the point as if they actually know something when they are full of theories, I like to deal with FACTS the fact is if you want to use them for "racing" they require a limit strap to limit the "suspension travel" to 2", their is a reason for this, its a SAFETY thing.
This guy is going to more than double the HP of his Pilot, he needs ALL the safety advantages he can get :-)
PostPosted: Tue Jul 29, 2008 4:08 pm
Fact are facts then pick your poison! We could debate for hours on me saying he got a compression fracture from a hard seat and you would say he smacked his head from slack in a belt. Either get hurt before or after. With your bad neck you more than anyone ( in my opinion!) would benifit the most from a suspension seat. You know you love the woops out at LS along the edges! How many times you flipped or ran into a tree in the last 15 yrs? I personally believe that the day to day "non-flipping or running into trees" driving I do that the suspesion seat helps protect my tired old bones.
Isn't a suspension seat and the slack issue the very same as a modern day automobile? Some get hurt, some don't. A flip of the coin maybe?
You believe your facts and I will believe mine.
You know I respect your opinion as much as or more than anyone else in this sport on all things including this just don't see things the same on this subject.
Be good!
Tom
PostPosted: Tue Jul 29, 2008 7:16 pm
Be good!
Tom
Ever watch crash test video where they test seat belts in autos, search and find some and watch, the slow mo videos show you alot, I never seen or heard about any seat belts in passenger cars and trucks that took roll overs into consideration, Lee probably can tell you if its considered or not.
Like I said before use what ever seat you want I really don't care, what I care about is ensuring anybody using one knows the facts about the seats then let them decide if they want slack in their harness EVERY time the suspension seat compresses, the professionals (sanction races) spell it out pretty clear to me regardless how many times I might need the safety equipment , they demand limit straps for a reason.
PostPosted: Tue Jul 29, 2008 9:46 pm
Anybody have any pics of a current production suspension seat? I have an older beard seat in the briggs and it is no where near as plush looking as the one that AK pilot just bought. I pulled mine apart last winter and it is nothing more than parachute cord pulled tight in a net formation. There is no give to it, standing in the web jumping on it sitting in it etc. The seat does not go up and down like an air seat in a truck. I did put this seat and the rest of the safetly gear up to a VERY serious test last month when the briggs car went end over end three times on a high speed WOT (Wide Open Throttle) double. The belts did not loosen up at all and the cage did not even bend to absorb shock. I have never been rocked so hard, ever. The crash destroyed the hood, exhaust, roof lid, lights, radiator, fans, air box, air filters, side scoop. Put my knees through the dash panel gauges (nothing keeps your legs from bouncing up and down), and a hell of a bloody mouth. The worst part was that I could not get out fast enough. I had had coolant running down my back and could not find the seat buckle release fast enough. Accoding to people who saw it the tires never hit the ground until it was all over so there was not shock absorbtion. The following day I ended up with a stiff neck and bruises on the knee caps. Not saying one is better than the other, just stating the facts of my experience in a situation that we need to prepare for and hope doesn't happen to often.
PostPosted: Tue Jul 29, 2008 10:36 pm
Amen!
PostPosted: Tue Jul 29, 2008 10:41 pm
Make sure you also to tell them the facts about a guy that had a compression fracture from a stock seat and that a suspension seat could possibly have saved him a lot of pain. All the facts must be told if any, not just the ones that reflect our opinion.
Tom
PostPosted: Tue Jul 29, 2008 11:48 pm
Don't most of these susp. seats require a skid plate at least in our buggies??? Mine does. and I wouldn't ride with out it for the simple fact I don't want something coming up and ripping me a new one!!! I have had to replace the foam in mine after a little mouse got into mine in storage and ate some out. So I have relaced mine twice now... once on install and that time... Mine has a plastic "panel" laced with parachute cord and I would like to see a better way to Lace this up tighter! I will have to use some enginerrin' to stretch real tight and keep it from giving...
I have "bottomed out and felt my arse hit my skid plate... Not a good thing...
What do the 700 horse power prerunner/buggies using for seats???
Score and BITD rules allow them with a very strict rule on slack in the bottom...
What does Nascar use???
I sat in Nuke'ems Kirkey seat and it was extremly uncomfortable simply because the side panels near my arm/elbows felt restricting. but in a rollover it would be better to keep me in the seat!!!
King they do make straps to keep your legs secure, I just don't remember who makes them!!! Glad you are ok...
Another point of contintion... are roll cages supposed to bend? to absorb shock??? What keeps them from impalling you once the start to give way on the first, second or third roll??? I wouldn'twant to have something collapse inward on me, and then not be able to get my fat arse out of the limited space on my ODY, much less the briggs smaller compartment??? Do you keep a fire squirter within YOUR reach in the cab???
JUST SOME THOUGHTS...
David
PostPosted: Tue Jul 29, 2008 11:57 pm
Tom
From what I read the above statement was based on His OPINION... really hard to tell unless a surgion piped in...
Just watched a nascar car hit the wall at 189 mph, and roll at least 6 times and the guy walked away!!! car 00. Not a nascar fan... but they spend millions on safety...
PostPosted: Wed Jul 30, 2008 12:28 am
Good Debate, I definetly see both sides. When I was down at the super sand car show in Orange County a few years back is when I decited on using a suspension seat. I can't recall a single car there without a suspension seat. It seems for the recreational rider they suscribe to the comfort over safety debate.
Right now it would be much easier to stick to the stock seat. It seams much, much less maintenance than the suspension seat. Right now I plan on taking out the seat for every power washing, where the stocker works wonderfully for that.
This seat is from Renegade, and was from someone who "knew" just what will work in a Pilot, last words from a salesman. The reason it is not in the FL800 now is because it wont fit between the seat tabs and made it even higher.
I not happy with how thick it is, It looks like the cusion is as tall as the sides of the seat. With out the seat cusion it seems just right, except pretty tight in the arse not something you would want to ride for an hour much less all day.
Here is a couple pics of the bottom construction of the seat.
Wayne
File comment: Looks like they used nylon rope to hold the nylon mesh. Litespeed how has the nylon rope you switched to held up? You can see the seat bottom bar is right at the washer/nut recessed in the mounting frame. The actual back bar of the seat frame is level
PostPosted: Wed Jul 30, 2008 12:50 am
The one in the pilot was the one that the cotton rope replaced with nylon but doesn't get used that much anymore. I replaced the seat in the Drak a few years back with a Corbeau also but it still has the original cotton rope. Still good to. I could have put the pilot away wet and the rope may have dry rotted, no clue on that. Anyway to answer your question it's holding up fine so far. It was some of that fine Homo-depot china rope I used and I'm sure it was built to last a life time. :)
Tom
PostPosted: Wed Jul 30, 2008 3:50 pm
I'm 6'1" and I have no change in seat height with my beard super seat. But I did cut out the stock mounts and welded in new mounts eliminating all the stock seat mounts.
PostPosted: Wed Jul 30, 2008 3:56 pm
How much slack or compression of a suspension seat are we talking about? 3" 4"? In my personal experiance( Just rolling my pilot 3 weeks ago) It doesnt move that much. If you actually strap yourself in the proper way, tight, real tight you wont feel that much movement while rolling( From what I remember).
PostPosted: Wed Jul 30, 2008 5:17 pm
Now there is some real world results!
Good to hear you didn't die and that the seat fits your tall height. I'm almost 6'4" and with my Corbeau it actually gave me more leg room from the more upright seating position but I lost about an inch on headroom. I lined my roll bars with foam just in case. ;
Tom
PostPosted: Wed Jul 30, 2008 8:40 pm
Hoser,
No worries about splitting the tread, I too think it needed it.
Also I did not even think of the added height for the steering post, it is removed right now. I'll definately put it in as check it out before I go much further.
Right now I can only imagine using this suspension seat without the bottom cusion for the height reasons. Yesterday I took out the foam from the shell and placed the shell in the bottom of the seat, it was better but you can still feel the seat bars on both sides of your arse. That will leave some nice bruses for the sole reason of using the suspension seat in the first place...bottoming out. Sure wish I did not purchase this $450 piece of crap!!! I guess that's why it 3 years old and not one mile on it.
Wayne
PostPosted: Thu Jul 31, 2008 9:51 am
While on the subject of seats..I have an N.O.S. pilot seat in blue ( no longer available) has been superseded to black
I am willing to part with..also have a mint condition seat belt set..
PostPosted: Sun Aug 03, 2008 9:25 am
Ody_Stable wrote:
Jeeezzzz...........
You're both smart enough not to let stupid words bother you like this right?
C'mon, call my mom some names, like I give a chit.........
Get over it already, dumbasses!
I personally like suspension seats, in light duty buggies, we have them in our buggy and the manx (like that will ever see action.........) and they are not as likely to be rolled.
I also personally would never use one in a Pilot or Odyssey because no matter how tight you cinch yourself down, it's just not going to be as tight as the stock seat would be. I have rolled Odysseys and I know I don't want to be moving around when I roll one of the Pilots and I KNOW it will happen.
C'mon bash me you BIG BAD BOY you.......
Dipsticks.........
Yup I would not hesitate to put a suspension seat in my Bug or Baja if I decide to go off roading I will probably install Litespeeds old Drakart seat, its like setting in a spoon keeps your butt in place, the stock seats offer no lateral support so I can see me sliding off the seat during a hard bumpy turn, I don't think my Baja will see any serious action or be rolled :shock:
PostPosted: Sun Aug 03, 2008 9:53 am
Here is a reply from Racecraft...
Quote:
Ok, got it now,, the spec guy was talking about the extra suspension bands under the seat. We put 2 2" pirelli straps under the seats for the race vehicles. The RaceSeat and Elite Seat are 'born' with them, on the other seats it is $15 per seat to put them on. We are ok'd for SCORE, SNORE, CORR and BITD
Gwyn Frantz
RaceCraft Seats
866-663-1358 xt 1
Registered users: c5racer, Google [Bot], Lanix, liduno
