It is currently Thu May 15, 2025 3:26 pm
PostPosted: Sun Nov 30, 2008 5:58 am
I just put one of these on and there is no rectifier regulator with this dose anyone know what i can use to make this work ?
PostPosted: Sun Nov 30, 2008 6:43 pm
is it a new "complete kit". Did you receive a wiring diagram. If not i've got mine somewhere - i could dig it up and post it if you need it.
PostPosted: Sun Nov 30, 2008 7:03 pm
found it but thr darn scanner is not working...
there is a yellow wire coming out of the motor (( Internal Combustion Engine ? )) - the goki kit has a yellow wire that has a male and a female connector on one end. by those connectors there is a thick spot in the wire. this is the rectifier i believe. the goki yellow wire plugs into the yellow wire from the motor (( Internal Combustion Engine ? )) and the other end goes to the soleniod connecting to the bolt on top that has the 4-1/2" red wire running to the + side of the battery.
hope this helps.
gokie's number - the last i knew was 818-998-0852
PostPosted: Sun Nov 30, 2008 7:52 pm
Seen this
viewtopic.php?t=4033&highlight=goki+wiring
OR how about this one?
viewtopic.php?t=1510&highlight=goki+diode
Gotta love the Search......
PostPosted: Sun Nov 30, 2008 7:55 pm
A few more while your reading
http://pilotodyssey.com/PO/viewtopic.ph ... t=charging
Another
viewtopic.php?t=2323&highlight=250+charging
