It is currently Sat May 17, 2025 10:59 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Dec 07, 2008 2:30 pm
Afastcar has another spare Engine he wanted me to CSI
Packing was pretty good it was the box in a box thing but the Engine was allowed to flop around inside the inner box, no good, they also didnt drain the oil out of the balancer case.
PostPosted: Sun Dec 07, 2008 2:31 pm
The Engine is pretty "COMPLETE" it even has the stock clutch, someone removed the plug and the bolt but the rest of the clutch is still their, its not worth much its well worn but still usable.
PostPosted: Sun Dec 07, 2008 2:32 pm
First thing I noticed is no serial numbers, NEW cases yeah!
PostPosted: Sun Dec 07, 2008 2:33 pm
One cylinder stud not screwed in all the way, hmmmm :shock:
PostPosted: Sun Dec 07, 2008 2:37 pm
These are all as found pics, silicone queer did up the intake manifold pretty good, the reed cage is missing and 1/2 the bolts were as you see them.
PostPosted: Sun Dec 07, 2008 2:38 pm
No dowel pins in the cases for the Engine mount, better order some so when this Engine is ready to be installed your sure to have them...
PostPosted: Sun Dec 07, 2008 2:39 pm
Rusty rod is never a good sign.
PostPosted: Sun Dec 07, 2008 2:40 pm
With the clutch off you can see the crank seal was not installed square into the case, its hard to see in the pic but the left side is not in far enough.
PostPosted: Sun Dec 07, 2008 2:42 pm
Copper coat on the head gasket 2.0mm over bore wiseco.
PostPosted: Sun Dec 07, 2008 2:43 pm
I had a hard time removing the wrist pin had to use the pin puller the whole way.
PostPosted: Sun Dec 07, 2008 2:46 pm
Time to go into the bottom end from the outside looking in it don't look pretty...
PostPosted: Sun Dec 07, 2008 2:47 pm
Someone used the wrong puller on this Engine you can see where they mushroomed the end of the crank, the nut came off real hard all the way....
PostPosted: Sun Dec 07, 2008 2:48 pm
It looks like a caveman wheel puller was used at one time .
PostPosted: Sun Dec 07, 2008 2:49 pm
Once removed you can see they had a hard time trying to get the WRONG TOOL to work.
PostPosted: Sun Dec 07, 2008 2:51 pm
Cases split, rust on the bearings no wonder they felt rough when you turned the Engine over by hand...
PostPosted: Sun Dec 07, 2008 2:52 pm
Top of the cylinder even had rust on it, the head was loose I assume the Engine quit running and they pulled the head then it rusted in storage?
PostPosted: Sun Dec 07, 2008 2:54 pm
Bore looks like the Engine was run without a filter and sucked a bunch of sand, I would like to see the filter setup on this Pilot, cylinder on last bore, new crank cases I bet this engines owner had a long and expensive life changing parts...
PostPosted: Sun Dec 07, 2008 3:00 pm
Quick list of parts needed.
4 dowel pins for the trans
2 dowel pins for the cylinder
cylinder replaced or new sleeve installed.
Piston, rings, wrist pin bearing, circlips.
Crankshaft rebuilt or replaced
crank bearings
crank seals
side case seal
full gasket set
reed cage (or use your current)
The crank cases look new, the balancer also looks new.
The crank has a blue mark on it, it looks like the big end of the rod bearing may have failed and the crank was rebuilt, I will take a closer look at it once I get it cleaned up.
PostPosted: Sun Dec 07, 2008 5:21 pm
wow that is one nasty motor (( Internal Combustion Engine ? )). Is it possible to have one of these old jugs plated? Can you install new sleeves hoser?
PostPosted: Sun Dec 07, 2008 9:28 pm
Yes the cylinder can be plated but if I was going to plate one I would plate it while still on the Honda bores.
I cant install a sleeve I don't have a milling machine but Speedchaser DOES hmmm
PostPosted: Sun Dec 07, 2008 10:14 pm
Sunblock wrote:
wow that is one nasty Engine. Is it possible to have one of these old jugs plated? Can you install new sleeves hoser?
o Hoser you can do it Bore the old sleeve out to new dimension of new sleeve.
Then grind new tool bit for top step on new sleeve
set stop for lip depth
put new sleeve in freezer for a day and slide in jug
and hope you get it wright on the first try
thanks speeed
PostPosted: Sun Dec 07, 2008 10:29 pm
Doesn't the original cylinder have a sleeve already? Put the cylinder in your wifes oven at 375 for an hour. Makes assembly and disassembly much easier. Kind of like removing steel pocket bearings from aluminum cases. Heat up the case evenly and the bearing literally fall out.
PostPosted: Sun Dec 07, 2008 10:44 pm
The factory sleeve in the Honda cylinder is cast in, I am told they have something on the outside of the sleeve that locks it into the aluminum once cast, must be ribs or something on the outside of the sleeve? I know I can take the cylinders off my 440 ROTAX and put them in the oven and heat, once hot the sleeves will drop out, some Engine builders remove them to make porting easier.
PostPosted: Sun Dec 07, 2008 10:50 pm
Heck I got to ride today and "H" to do tare down. I bet we both hade fun. motor (( Internal Combustion Engine ? )) does look nasty thu. Theres a grand for sure. Here latly seams to be a lot of nasty looking motrs out there to repair. Mine just hit 52 hr's. time to take a peak before summer. Comp still good so should be minor.
PostPosted: Tue Dec 09, 2008 2:33 am
interesting ideas about the sleeve, since I have a jug with a broken skirt I may try that oven trick and just see what happens.
Registered users: Bing [Bot], Google [Bot], liduno, MSN [Bot], Q
