It is currently Sun May 18, 2025 9:57 pm
PostPosted: Thu Jan 01, 2009 8:33 pm
Anyone know if a 12" wide tire mounted on the douglas beadlocks will fit without rubbing on the pilot. The tire is a titan 589 25x12x10 I have not mounted them onto the beadlocks yet, so I don't know if they will clear the suspension arms/ball joint boot.
PostPosted: Thu Jan 01, 2009 11:12 pm
If my memory serves me it will not fit without rubbing. :shock:
PostPosted: Fri Jan 02, 2009 10:48 am
Can you mount them on a deeper dish rim(more out from hub center)?
PostPosted: Fri Jan 02, 2009 11:09 am
HMMMM-MIGHT WORK WITH A DIFFERENT OFFSET ON THE BACKING PLATE---
PostPosted: Fri Jan 02, 2009 12:08 pm
I believe the rims I run the 22X12.50X10 Spider Traks on are 3 in 5 outs. They are closer to the upper adj stay support than I like but don't rub. Not real sure on Pilot suspension layout. Got any pics showing the clearance area issue?
