It is currently Sat May 17, 2025 4:10 pm
PostPosted: Sun Jan 18, 2009 4:01 pm
Mudbogger picked up a Pilot Engine off evilbay, on the outside it looks like a clean, heck the cases are not stained with oil, grease, mud the plated items like the recoil housing nuts and bolts not tarnished or rusted, rubber and plastic items are in good shape.
On the bottom of the Engine wrote in black marker it says fast 33 race what ever that means..
PostPosted: Sun Jan 18, 2009 4:02 pm
Behind the recoil cover the usual dirt and mud no signs the oil seal is leaking.
PostPosted: Sun Jan 18, 2009 4:03 pm
Looking into the cooling system you see some rust and goop green residue.
PostPosted: Sun Jan 18, 2009 4:05 pm
With the intake off I found a stock reed cage with boyseen reeds installed, you can see in the pic where they cleaned up the castings, what you can see in this pic is about all they done, they did grind on the exhaust port a little but really made no changes.
PostPosted: Sun Jan 18, 2009 4:06 pm
The piston is on stock bore but both the cylinder and piston are plenty worn the cylinder will need bored to the first over bore.
PostPosted: Sun Jan 18, 2009 4:08 pm
Nice burn pattern
PostPosted: Sun Jan 18, 2009 4:10 pm
Other than the usual foreign material from the Engine being removed from the Pilot and the intake and exhaust being opened up the bottom end is clean and extremely tight.
PostPosted: Sun Jan 18, 2009 4:12 pm
Typical rust found between the clutch and crank seal, I will pull the seal to see how far the rust had creeped into the inner lip of the seal.
PostPosted: Sun Jan 18, 2009 4:14 pm
Some pics of the cylinder
PostPosted: Sun Jan 18, 2009 4:17 pm
The head looks stock and undamaged.
PostPosted: Sun Jan 18, 2009 4:18 pm
No changes were made to the transfers.
PostPosted: Sun Jan 18, 2009 4:19 pm
The exhaust port is a mess and will require a lot of time and attention to correct it.
PostPosted: Sun Jan 18, 2009 5:41 pm
ok, so I need to order 0.25 piston-rings, wristpin, circlips,jug gasket-reed gasket-crank seal anything else?
PostPosted: Thu Jan 22, 2009 1:57 pm
Service Honda emailed me today Hoser-wristpins are on backorder with no ETA on availability-great huh?pisses me off as I got email the order was shipped then a day later they tell me a part is backordered,but what can you do?
the other parts are on the way to you-please let me know when they get in-
PostPosted: Thu Jan 22, 2009 3:14 pm
there should be 2 extra pins with my order you can take one and just replace it when yours come in.
PostPosted: Thu Jan 22, 2009 8:06 pm
Well thank you very much- :-) I will take you up on that offer-they(meaning SERVICE)have no ETA on when it will be in, that's ok with you?As soon as it comes in it will be shipped to HOSERS compound for your replacement.Thanks again AFASTCAR for the generous offer!!! :-)
PostPosted: Thu Jan 22, 2009 8:12 pm
no problem........ just check with Hoser and see if all 3 piston sets came with my order.
PostPosted: Thu Jan 22, 2009 8:18 pm
well do-thanks again!! -::
PostPosted: Tue Jan 27, 2009 6:36 pm
wristpin came today in mail, as well as the dowels I ordered too-so AFASTCAR thanks but I will not need the pin after all!!!apprec the offer again---
Hoser-all parts in box and on way to you including SPEEDCHASER head and some rear trailing arms I had wanted HOSERIZED please--
PostPosted: Sat Feb 14, 2009 10:13 am
Hoser everything get to you with what you needed?I have 2 projects going on so I wanted to make sure you have what is needed as I have SERVICE orders coming and going these days.
PostPosted: Sun Mar 01, 2009 5:36 pm
Are you going with a Speechaser Cool Head on this Engine?
I have one setting on my bench I can install then you can have him ship me one later...
PostPosted: Sun Mar 01, 2009 6:08 pm
I shipped 1 with the arms and gaskets--find it?
PostPosted: Sun Mar 01, 2009 6:16 pm
Yuppers it was in the bottom of the box :-)
PostPosted: Mon May 25, 2009 11:45 am
Got motor (( Internal Combustion Engine ? )) back from Hoser-as always great job Hoser-apprec it greatly-this is going into Odykids Project Pilot see the thread in "projects" for updates on this motor (( Internal Combustion Engine ? )).
