It is currently Wed May 14, 2025 11:27 pm
Post new topic Reply to topic  [ 156 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Thu Feb 19, 2009 3:03 pm
redskinman wrote:
Sunblock wrote:
yeah, that's pretty low. I would go ahead and bore it. wiseco piston kits are usually around 100 bucks on ebay, that plus 45 or so for the bore and you will be on your way to having a nice runner.
With the compression being so low the piston clearance maybe so large that the piston slaps a bit while running, When you run a piston like that it will crack the skirt and drop metal chunks all in your bottom end. Then you will have a much more involved rebuild on your hands. The clearance on your crank is good enough to where I would just fix it right so you do not have to pull it apart anytime soon.
The cylinder and piston don't show any signs of piston slap,I'd hate to lose a bore that I don't need.I brought the piston to work today and with the mm gauge I have here I measured 80 mms,I thought i read somewhere that 82 is the last one it will take,so that only leaves me with 1 bore left,amI correct in my thinking?
thanks
wiseco pistons for the fl350
80mm 80.5mm 81mm 81.5mm 82mm last one is 82mm
now did you measure with a feller Gage piston bottom to the bore
wiseco are to be .004 Gage or .002 per side
that will tell you if you need to bore to the next size that's the backyard hacker way
OR mike the out side of piston and find that largest size then
use a bore Gage to measure to bore to find the differences
thanks SpeedChaser
PostPosted: Thu Feb 19, 2009 3:12 pm
thanks
thanks SpeedChaser
I did not measure with a feeler gauge,measured outside of piston with digital caliper,I'm going to find a machine shop to measure everything and get their opinion,that's probably the best thing for me to do
thanks
PostPosted: Thu Feb 19, 2009 7:31 pm
I wouldn't get too attached to the cylinder either, those 4 bores will last you a long time if you jet properly and run a good synthetic premix oil. If you check ebay often you can find cylinders in the 50-100 range with several bores left.
I let this one go recently as I already have a spare .
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
certainly don't waste a bore, but being down at 90psi .. I would start leaning that way.
If you do just replace the rings let us know what type of increase you see, I am curious to find out.
PostPosted: Thu Feb 19, 2009 7:54 pm
the honda shop gave me this guys number who works on older 2 strokes,they called him the"honda doctor" I'm going to take the piston and cylinder to him and get an expert opinion on it,that wont be till my next day off {sat 28th} so i'm in nuetral till then,
thanks everybody for your help so far
PostPosted: Thu Feb 19, 2009 11:24 pm
If I do need to replace the piston,any suggestions on who to buy from? I ordered some small stuff from chucklenuts at aftershot motorspurts motorsports and was happy with them. Looks like odyssey salvage has the best price,195 for piston and gaskets
Pilot oddy performance was 154.00 for the piston and 46 for the gaskets for total of 200.00,chucklenuts at aftershot motorspurts had piston for 169.95 and 19.95 to drill out piston,not sure how much for gaskets,they had a gasket kit for 76 bucks but i don't know if that's just for the top end or what.
I do know i want to have the piston drilled but i don't want to attempt it myself,does anyone else do the drilling besides chucklenuts at aftershot motorspurts motorsports?
what do you guys recommend?
thanks
PostPosted: Thu Feb 19, 2009 11:27 pm
thanks
ok,whats the inside joke Im not aware of regarding aftershot?
PostPosted: Fri Feb 20, 2009 12:34 am
he sucks and is just a middleman taking your stuff to another shop to get work done
hes not allowed around these parts.
PostPosted: Fri Feb 20, 2009 12:53 am
wow,why don't you tell me what you really think of him :-) guess I shouldn't have said i bought something from him,lol
PostPosted: Fri Feb 20, 2009 2:39 am
I haven't posted alot here but have read the same thing about chucklenuts at aftershot motorspurts several times. I think there is someone that will do you cylinder pretty inexpensive on the board. Hoser do you have any ideas?
PostPosted: Fri Feb 20, 2009 8:17 am
Hello the piston are here on ebay
http://shop.ebay.com/?_from=R40&_trksid ... Categories
and you should go out and buy some feeler gauges. Check what you have before you go see what the other person says
so you are both on the same page.
take some more pic's of the piston and how thick of a feeler Gauge you can slide in on one side of piston in the bore.
bottom of skirt of piston to bore of cylinder
it is just nice knowing what you have so some one will not blind side you on a new bore .
thanks SpeedChaser
P.S. where are you located state that all
PostPosted: Fri Feb 20, 2009 4:58 pm
since you asked, go about halfway down and start reading
http://pilotodyssey.com/PO/viewtopic.ph ... sc&start=0
i would buy parts from him if he was the cheapest, but again maybe i wouldn't, honesty goes a long way
PostPosted: Fri Feb 20, 2009 5:13 pm
My last 350 piston kit came from ebay, and was 99 bucks for rings piston circlips and wristpin bearing. They seem to fluctuate a bit. I have dealt with randy at odyssey salvage a few times. he is a nice guy but can be real slow in getting back to you, and often difficult to get a hold of.
PostPosted: Fri Feb 20, 2009 5:15 pm
did you drill the piston yourself? will randy at ody salvage do that for you?
PostPosted: Fri Feb 20, 2009 5:28 pm
No I did not drill it myself, any shop that does boring should be able to do it for you though, it is a pretty common thing to do to 2-strokes. I would just call around to some local bike shops and ask if they do 2-stroke boring. You should mention that your cylinder is not plated too as that makes a difference to the person doing the work.
I think its pretty easy though, I will probably drill the next one I do on my own.
PostPosted: Sat Feb 21, 2009 11:38 am
I drilled my own on my piston, was pretty easy. The instructions I had were pretty clear so no big deal.
my $.02
JIm
PostPosted: Sat Feb 21, 2009 12:37 pm
my $.02
JIm
wheres the instructions?
PostPosted: Sat Feb 21, 2009 1:49 pm
redskinman wrote:
my $.02
JIm
They come with the piston
Some info on it here
viewtopic.php?t=4212&postdays=0&postorder=asc&highlight=350+cylinder&start=12
Some piston prep info viewtopic.php?t=3399&highlight=port+bevel
Port bevel info viewtopic.php?t=3702&highlight=port+bevel
PostPosted: Sun Feb 22, 2009 5:39 pm
thanks hoser
heres some more pics,just cleaning them up now,getting old gaskets off and stuff
Did the quick and dirty method for cylinder check,thickest feeler I could get in was .003.Like I said before,I don't know what I'm doing,will be taking it to a professional sat
PostPosted: Wed Feb 25, 2009 11:06 pm
honda dr was no help,he doesnt have machine big enough to bore it,but he thought it needed bored out.My neighbor came by and looked at it and he thought the cylinder looked fine.I need a pro but having a hard time finding one
PostPosted: Fri Mar 06, 2009 11:12 pm
well i have the cylinder sent out to be bored,got the complete set of gaskets from service honda today,got a new fuel pump,just waiting to take the next step,cant wait to get this thing running again
 Post subject: putting back together
PostPosted: Mon Apr 13, 2009 9:25 pm
now the title of this thread should be caleed need help putting back together for the first time
got my cylinder back today so will be starting soon on it,had some questions before starting
1.does the piston face the exhaust port where the holes are drilled in piston?
2.do you put something on the cylinder to hold the gaskets?
3.ordered the complete set of gaskets from service honda,the bottom gasket is just one metal gasket but the top gasket is 3 stuck together{see pics}I think ive read different views on how many gaskets to use,so need some advice,
thanks again to hoser for all the help
PostPosted: Tue Apr 14, 2009 12:00 am
You will need to get a 3/8 drive torque wrench and the motion pro tool below
http://www.motionpro.com/motorcycle/too ... h_adapter/
then read this...
http://pilotodyssey.com/PO/viewtopic.ph ... motion+pro
Ask Hoser for his suggestions on the top or head gasket... I am using all 3. Only because I am not real good at checking the squish yet...
Do as much as you can before you put it into the ODY... Put it together and do a leakdown test on the bench just because it is easier! You figure out the leakdown tool yet????
I lost a piston because the fuel pump hose that is behind the clutch was loose. I also ALMOST lost one because this hose was too big, so get a clutch tool to hold it in place... Tool will depend on who made the clutch...
I am sure there is more, but it is late...
David
PostPosted: Tue Apr 14, 2009 1:53 am
1. yes, the purpose of the holes is to help lubricate and cool the bridge in the exhaust port to keep it from swelling. That is the hottest part of the cylinder and a common source of seizures in stock motors. There is usually an arrow on the top of the piston as well that points to the exhaust port.
2. I have never used any type of sealer or such on the head or cylinder gaskets. Not sure if they make anything designed for use in those areas.
3. Most will just use one of the thin outer layers of the head gasket when running the stock head. Aftermarket heads have smaller domes and can create high amounts of compression so using the complete gasket is better for those, I just learned that one the hard way. see my recent seizure thread.
viewtopic.php?t=5330
which ever you go with just check the compression and see where you are at. using the full gasket will lower the compression and using the thin part will increase it. I think stock is around 130 or so ???? some one will correct me on that.
Turbo is right too, make sure you use a torque wrench when tightening the head nuts back up. They are very easy to over tighten and strip out the stud hole. Also learned that one the hard way :-) I got mine from northern tool for $35 bucks or so, and it is a must for working on atvs of any kind.
PostPosted: Tue Apr 14, 2009 2:34 am
No sealer is required... learned this the hard way too... it just makes a mess...
PostPosted: Tue Apr 14, 2009 7:30 am
I've already bought the tool,thanks
[/quote]then read this...
Do as much as you can before you put it into the ODY... Put it together and do a leakdown test on the bench just because it is easier! You figure out the leakdown tool yet????[/quote]
no,don't have a tool yet,motor (( Internal Combustion Engine ? )) is not out of the ody to do a test on the bench
[/quote]I lost a piston because the fuel pump hose that is behind the clutch was loose. I also ALMOST lost one because this hose was too big, so get a clutch tool to hold it in place... Tool will depend on who made the clutch...[/quote]
when my trouble first started I noticed this hose off the clutch but wasn't sure if i pulled it off messing with it or if it came off by itself,I didnt realize you could lose a piston from this being off.Not sure what your talking about to hold it in place?
David
Registered users: Baidu [Spider], Bing [Bot], Google [Bot], John l, Lanix, Q, Rppjr, stix
