Oldmanody wrote:
i have a question about clearance
do you think that after you bore and hone your cylinder set your clearance and then torque it down to spec - is there a possibibility that the roundness of the cylinder might change?
Yes no maybe, lets put it this way not enough to worry about building a torque plate for the FL250 FL350 FL400's if the stud placement was a problem you would plainly see it in wear on a cylinder during your rebuilds, Macdizzy thinks this might be an issue on the 300cc big bore kit I got for my ATC250R because of the wear patterns seen on the cylinder walls, I will see of the wear he sees matches the stud pattern, we cant discount some mutt over torquing the head some time in the past either, one of the studs threads is messed up not sure what caused the damage but the stud is junk.
I have not seen it as a issue on the Pilots or Odysseys under normal wear and tear, I am more concerned about how clean the air is coming into the Engine, I have seen more abnormal wear because of dirt ingestion than anything else, next would be over heating of the air cooled engines, if I owned a FL350 the first mod would be air blowing on the front of the cylinder where you always see aluminum pistons stuck to.
