It is currently Wed May 14, 2025 6:27 am
PostPosted: Sun May 17, 2009 8:39 pm
I'm going back to my drag racing roots, so it's time for the Piranha to go. It's got an 2005 EFI GSXR 600 Engine, custom Doug Heim/Rick S. rear suspension and driveline(uses Porsche 924 cv axles), Kenda BearClaw tires on black ITP Baja wheels, Corbeau Baja suspension seat, rack and pinion steering, Wilwood front brake calipers, 530 chain drive, GSXR fuel pump, custom fuel tank and fuel lines, all TIG welded frame which has been widened for more drive room, clutch/brake/gas pedals are mounted, wilwood master cylinder, custom aluminum body panels.
It needs rear brake caliper and mount, brake plumbing, Engine wiring, fuel cell finished and mounted, front and rear shocks, throttle cable routed and mounted, idler sprocket mounted, floor pan, finish fabricating exhaust, misc other small details.
It really doesn't need much to be up and running. I've been traveling a lot for work, and I've ben drawn back into drag racing. This is just sitting in the garage taking up space and collecting dust. With a little effort someone could have a nice buggy. I've can take more pics if you'd like to see something specific.
I'm asking $2800 as it sits, you must come to Houston Texas to get it.
PostPosted: Mon May 18, 2009 1:35 am
looks pretty cool. I'd come check it out if you were closer.
Do you have any other pics of the fabrication process? I would be very curious to see how this thing is put together.
PostPosted: Mon May 18, 2009 11:33 pm
I've got a few more pictures buried somewhere on my computer. I'll try to dig them up. I spent more time actually fabricating than photographing.
Actually this thing is not overly difficult to build. It requires a failry large flat surface. I but several "sections" and then put them all together.
North Carolina isn't too far from Texas. The beer will be nice and cold by the time you get here!!
Troy
PostPosted: Tue May 19, 2009 9:33 am
Send me some more pics. kingjason@swbell.net also a little more detail on the finishing steps. I am interested.
PostPosted: Tue May 19, 2009 11:10 pm
kingjason, I sent you a couple of e-mails.
Troy
PostPosted: Wed Jun 03, 2009 11:24 am
New Price......$2500.....it needs to go!!!
PostPosted: Thu Jun 25, 2009 8:15 am
Still have it? Might be a fun project.
Thanks,
John
PostPosted: Thu Jul 09, 2009 10:56 pm
Sorry for the late response......I sent you a PM.
Troy
PostPosted: Mon Aug 24, 2009 8:35 pm
Will consider trading for a nice dirtbike.
T
PostPosted: Sun Aug 30, 2009 8:07 pm
SOLD
