It is currently Wed May 14, 2025 5:21 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
PostPosted: Fri Sep 18, 2009 5:48 pm
Turbo started a thread on his Engine here viewtopic.php?t=5915" ."..
He sent me his Engine for a CSI so I started another thread here.
Pulled the flywheel popped right off using the correct puller, noticed part of the stator is discolored a little, lighting coil windings getting hotter than the ignition windings?
PostPosted: Fri Sep 18, 2009 5:49 pm
Stator out of the way don't look like the seal was leaking.
PostPosted: Fri Sep 18, 2009 5:52 pm
You can see the gasket sticking out of the cases that probably why Turbo could not hold pressure on the leak down test, right now I ASSume when the big end rod bearing failed the rod then made contact with the cases and spread the cases just enough the gasket no longer has compression on it, will know for sure once the cases are split.
File comment: Can pull it out with my fingers
PostPosted: Fri Sep 18, 2009 5:56 pm
This cylinder was supposedly ported by ATV Racing?
The only thing that's been done to this cylinder was the exhaust was modified slightly, hope you didnt pay for "porting" this is not the FIRST cylinder I seen that came from ATV Racing that was allegedly "ported" .
File comment: Transfer port roofs never been touched.
File comment: Transfer ports not touched.
PostPosted: Fri Sep 18, 2009 5:57 pm
wow never new the cases could distort like that and not crack
Stock reed cage with boyseen reeds
PostPosted: Fri Sep 18, 2009 5:58 pm
Rod is toast time to find another crank or figure out who to send this one to for a rebuild.
PROX rod was installed the last time, is the HONDA rods still available?
FL350 replacement rod kit ProX Connecting Rod 03.1315
Our Price: $68.44 http://www.powersportsuperstore.com/Pro ... lick=35177
PostPosted: Fri Sep 18, 2009 6:00 pm
Balancer cover bolts were not very tight maybe TuroTexas had already removed them?
Also noticed the large nut on the crank was not staked.
hoser can those cases be saved after distorting like that
PostPosted: Fri Sep 18, 2009 6:02 pm
More info once I get the cases split and the crank out.
Parts list so far.
Crankshaft
Complete gasket kit (honda still has them I hope?)
Crank bearings
Crank seals
Piston and rings
Wrist pin bearing
Wrist pin
Circlips (TWO needed)
PostPosted: Fri Sep 18, 2009 6:09 pm
Usually the gasket surfaces can be lapped down enough they will seal perfectly once again, wont know for sure until I get them apart and see what the real damage is.
PostPosted: Fri Sep 18, 2009 8:04 pm
Did ATVR really say they ported the jug?holy crap if that doesn't make you want to call the local public advocate huh?Mial fraud?false advertisement?
PostPosted: Sat Sep 19, 2009 12:35 am
I removed the balancer cover, and tried to remove the big nut so I left the backing down...
I asked for and was told I wanted a mild porting as at the time I was only wanting reliability over Race ready... Now I want both LOL They called it a trail porting??? The exhaust side might have been done by the local machinist in San Antonio as when I replaced last piston he bored and releived the bridge...
PostPosted: Sat Sep 19, 2009 7:25 am
Pic #3550,does'nt look like much of a bridge left! :shock:
Plus it snakes! :shock: Would not be very good from keeping the ring from wanting to turn.
PostPosted: Sat Sep 19, 2009 10:21 am
I hope you didnt pay ATV Racing for 'porting' or 'trail porting' because they spent about 10 minutes cleaning up the exhaust, heck they didnt even match the exhaust port, signs they just don't have a clue!
Some place I have a port map of a stock FL350 I will see if I can find it and see what changes were made to the exhaust, it looks like it was raised and they might have even lowered the floor a little, don't look like they made it any wider.
Anybody know the status on 350 cranks, can you still get a new crank from Honda, how about rod parts?
Speedchaser rebuilding cranks yet, on other sites I keep hearing any machinist can rebuild cranks...
PostPosted: Sat Sep 19, 2009 10:25 am
I wish I still had the reciept... I even asked them to fix the oil leaking into the starter... I bet that wasn't donne either...
PostPosted: Sat Sep 19, 2009 10:27 am
The more time that passes the more it seems ATVR is not playing very nice, its a shame the shop forman or manager is not doing their job.
PostPosted: Sat Sep 19, 2009 11:55 am
Honda cranks still available for the 350's?I never bought 1-Wonder if ED and SARA have any old stock laying around from the shop they might sell Turbo, try them.
PostPosted: Sat Sep 19, 2009 12:18 pm
You have contact info???
PostPosted: Sat Sep 19, 2009 12:57 pm
1-800-763-3762 http://www.expresspages.com/t/triplee/ Sara's E-mail address at Triple E... smorrisk@yahoo.com
PostPosted: Sat Sep 19, 2009 1:03 pm
Website didn't work, I will drop an email...
PostPosted: Sat Sep 19, 2009 1:13 pm
Email was a bust too...
PostPosted: Sat Sep 19, 2009 7:30 pm
I am sorry Turbo, I haven't spoken to them in months-just was thinking-oh well.Have any luck with Randy Bridgewater?
PostPosted: Sat Sep 19, 2009 10:30 pm
I haven't started looking yet, I saw on Service honda they had a price on the rod about $105.00 but I am waiting to see the rest of the CSI before I drop any money... In case there is a need for something different... I am kicking myself for not being prepared with a back up motor (( Internal Combustion Engine ? )), I have a back up tranny... LOL But it don't do me no good now LOL I am also going to get a second motor (( Internal Combustion Engine ? )) in the future when this one is done!
