It is currently Tue May 13, 2025 6:56 am
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Mar 17, 2010 9:48 am
Hello All
Hoser wanted me to rebuild cranks so I thought I would have a go at it
Started out with a lightly used punching die set I had laying around, going to turn it into a two stroke crankshaft rebuilding tool so I can rebuild 2 stroke crankshafts
Thanks For Looking
SpeedChaser
MVC-279X.JPG [116.53 KiB]
Downloaded 492 times
File comment: after sawing
File comment: after milling flat
File comment: pre assembly
File comment: look at with fl350 crank
MVC-286X.JPG [113.83 KiB]
next
I will be boring holes for removable bushing.
for the main bearing to do different size cranks.
File comment: setting up on mill
MVC-288X.JPG [114.51 KiB]
Downloaded 393 times
File comment: drilling a 1.600 dia. hole
MVC-289X.JPG [91.41 KiB]
MVC-291X.JPG [108.43 KiB]
MVC-293X.JPG [89.71 KiB]
File comment: run a 1-3/4 dia reamer thru
MVC-294X.JPG [113.7 KiB]
File comment: all done reaming
MVC-295X.JPG [99.39 KiB]
PostPosted: Wed Mar 17, 2010 9:49 am
Added risers to add weight to the bottom shoe and add strength
next up risers for top shoe and mount for press
then start on bushing for locating the cranks
File comment: adding some risers
MVC-298X.JPG [96.3 KiB]
Downloaded 364 times
File comment: using my old radial arm drill press
built just after ww2
File comment: need to clean my bench what a mess
all done on to bushings for the fl350
Thanks For Looking
SpeedChaser
File comment: building top risers and hydraulic mount block
MVC-311X.JPG [116.52 KiB]
Downloaded 355 times
MVC-313X.JPG [111.85 KiB]
File comment: all done on to bushings for the fl350
PostPosted: Wed Mar 17, 2010 10:42 am
About time !
I know of 3-4 FL350 cranks that need rebuilt!
I have 2 Pilot cranks you can do!
I have one TRX250R crank you can do!
I have one 83 ATC250R crank you can do possibly a second one of the same year
I bet I know of 3-4 other Pilot cranks that need done!
When you get those all done I have a crank out of a 1979 440 ROTAX you can do its a twin cylinder a little more tricky requires a different jig.
PostPosted: Wed Mar 17, 2010 7:30 pm
you are the man speed. I have some cranks as well. question though, are the crank parts for 350s still easy to get? theres an aftermarket kit on ebay now, but I don't know if its really necessary to replace the rod? I have some dead cranks laying around from various bikes I can send your way if you just want something to practice with.
PostPosted: Wed Mar 17, 2010 11:08 pm
Hoser send him mine for his first attempt!!!
PostPosted: Fri Mar 19, 2010 9:50 pm
I have many 350 cranks Speed,2 Pilot cranks that need work.
PostPosted: Thu Mar 25, 2010 10:53 am
bump add new pic's
PostPosted: Thu Mar 25, 2010 11:16 am
speedchaser wrote:
bump add new pic's
Getting closer
Have you pressed any cranks with it?
PostPosted: Thu Mar 25, 2010 11:20 am
speedchaser wrote:
bump add new pic's
Getting closer
not yet I have a fl350 crank sitting here with a ugly look on it face
that will be the first victim :-)
thanks Speed
PostPosted: Sun Mar 28, 2010 11:29 am
bump add more pic's
next up is bushing for different style cranks
thanks for looking
speed
PostPosted: Sun Mar 28, 2010 11:58 am
Speed I also have 2 Pilot cranks that need rebuilt.
PostPosted: Sun Mar 28, 2010 12:04 pm
http://www.jktuning.co.uk/crankshaft.htm
http://www.rrracing.co.nz/crank/index.html
Start looking for a chunk of pipe so you can do my snowmobile crank heh
https://www.youtube.com/watch?v=HxcWz4D7BmA
https://www.youtube.com/watch?v=zUFjrd2cKSY
https://www.youtube.com/watch?v=bTxYxkGjI6U
Rebuilding Crankshaft
Crankshaft rebuild
PostPosted: Sun Apr 11, 2010 2:23 pm
Updates?
Guy needs a crank... http://www.pilotodyssey.com/PO/view ... crankshaft
PostPosted: Sun Apr 11, 2010 2:30 pm
yep waiting on rod kit for the fl350
should get this week
will up date soon
thanks speed
PostPosted: Sun Apr 11, 2010 2:40 pm
will up date soon
thanks speed
Where did you get the rod kit, and what was its cost ? The only ones I have seen are off of ebay.
PostPosted: Sun Apr 11, 2010 2:46 pm
will up date soon
thanks speed
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0489695591
http://pilotodysseyperformance.com/inde ... %20Rods%27
has them too
yes that is where I'm still looking for better prices too
thanks Speed
PostPosted: Sun Apr 11, 2010 4:00 pm
speedchaser wrote:
will up date soon
thanks speed
has them too
thanks Speed
Feed back I am getting is PRO-X then Hot Rods but every one of the Hot Rods needs checked before installing guys are seeing about a 30% rejection rate right out of the box, then Vesrah brand.
Last I looked Vesrah was looking for dealers, might pay to check with PRO-X and see if they will make you a dealer?
PostPosted: Tue Apr 13, 2010 7:50 pm
came across a bench center today cheep $35 needs some modding thou
I will make it work
thanks for looking
Speed :-)
MVC-336X.JPG [108.17 KiB]
Downloaded 379 times
MVC-337X.JPG [110.67 KiB]
PostPosted: Thu Apr 29, 2010 10:10 am
what you think on spec sheet any spot need to be there ?
thanks speed
PostPosted: Thu Apr 29, 2010 10:19 am
thanks speed
Looks like you have it covered, what about the rod?
PostPosted: Thu Apr 29, 2010 10:26 am
thanks speed
like what you thinking
dose it need to be specked out ?
PostPosted: Thu Apr 29, 2010 10:38 am
speedchaser wrote:
thanks speed
Yeah from what I have read the new rods should be checked I will find a diagram that will help and post.
 Post subject: pressing crank apart
PostPosted: Thu Apr 29, 2010 12:01 pm
I press this bugger apart
not bad to do I have pressed a lot harder thing
Speed
MVC-347X.JPG [65.12 KiB]
Downloaded 331 times
MVC-352X.JPG [83.48 KiB]
Downloaded 330 times
File comment: each shinny line is a deep grove
