It is currently Sun May 18, 2025 7:25 pm
PostPosted: Wed Mar 24, 2010 7:08 pm
I have a friend with a plasma nitrogen laser engraving mill. I can for sure cut out gaskets if i can get the right materials and measurements.
I am looking to make head and base gaskets for both FL350 and FL400
Here is info i have:
FL350 base Gasket thickness @ 0.15
FL350 Scan of head and base
Here is info i need:
[X] FL400 Base Scan @ 600DPI(300 will do)
[X] FL400 Head Scan @ 600DPI(300 will do)
[ ] FL400 Base thickness .015 or .021?
[ ] FL400 Head Thickness .032?
[ ] FL350 Head Thickness (what is best?)
Copper or Aluminum? Aluminum for Base? Copper for head? Copper for both?
polished copper? or unfinished copper?
What Alloy?
Anyone have Used Pilot gaskets they would be willing to donate for this project?
so far a 12 inch by 48 inch (.016) thick sheet of copper runs about 50 bucks unpolished, same thing in aluminum runs about 10 bucks. I am still looking for polished metals thinner than .032.
PostPosted: Wed Mar 24, 2010 8:05 pm
this FL400 head gasket on ebay looks to be unpolished and is .032 thick by description.
http://cgi.ebay.com/ebaymotors/HONDA-FL ... ccessories
PostPosted: Wed Mar 24, 2010 8:13 pm
How about producing some of the pilot trans gaskets that are no longer available?
PostPosted: Wed Mar 24, 2010 8:18 pm
any type is possible really.. only hard part would be getting a scan of the trans gasket as it is too large.
I could take it to work and use the large format scanner there though :)
anyone want to get me a scan of a pilot trans gasket? either that or send me one. probably standard wafer material for trans?
PostPosted: Wed Mar 24, 2010 9:01 pm
Pilot cylinder gasket
PostPosted: Wed Mar 24, 2010 9:04 pm
Pilot head gasket
PostPosted: Wed Mar 24, 2010 9:11 pm
Ask your laser guy how flat he can keep the copper and aluminum being that Thin I think he will run it to problems
but I been wrong before :-)
The way I was going after them was steel rule die or some times call a cookie cutter die goggle it
http://www.google.com/search?q=steel+ru ... =firefox-a
I can have the die built for under $150 each fl350 head and base gasket.
and they will cut up to .045 soft copper or aluminum and keep the pretty flat too
P.s. what price where you looking to get out a fl350 copper head gasket and a aluminum base ?
thanks SpeedChaser
PostPosted: Wed Mar 24, 2010 10:07 pm
here are some measurements i made with photoshop digital ruler. Can you double check these for me on the actual gaskets to make sure the DPI is precise.
thanks for the scans!
PostPosted: Wed Mar 24, 2010 10:53 pm
thanks SpeedChaser
it wont be a problem to keep flat i hope, the whole plotter table has a honeycomb mesh and really powerful vacuum. if you put your hand on it, its hard to remove. We will have to paper off most of the open table space to concentrate the vacuum to the area the metal is sitting also.
and as far as price? im not too sure actually. It depends on the price of raw materials. On the forum i don't think i would really be looking to make a profit as i feel i owe something to the community. Assuming i don't have to buy polished finish metal: aluminum base should be fairly cheap. copper would be more. I'm going to look around locally at some shops and see what i can get. I couldn't find polished finish any thinner than .032 (which might be the correct width for head gasket on pilot)
24"x24" @ .032" of polished copper on McMaster is 123 bux!
24"x24" @ .032" of brushed copper @ 100 bux
36"x48" @ .032' unfinished @ 139 by far best deal.
if a 24 x 24 has total surface area of 576 sq.in. and a head gasket takes a little less than 30 sq in i should be able to fit around 16. math would say 19 but the edge doesn't have usable space. attached is a picture that is to scale(but scaled down proportionately) of the layout on a 24x24 copper sheet with roughly 5.5x5.5 sized heads.
so assuming polished copper @ 123 bux/16 gaskets = 7.68 cost per unit to make+shipping(assuming ray doesn't charge me to use machine). What do you think would be a fair forum price? 20 shipped? are they worth more?
Brushed = 6.25 each
unfinished 36x48 = 139/53 gaskets (tough squeeze) = $2.62 a piece
if the unfinished copper are usable, or even if i can buy the unfinished and polish/sand by hand it would be by far best option.
PostPosted: Wed Mar 24, 2010 11:30 pm
lutrev wrote:
Stock gaskets need to be larger in the cylinder area? Most 350s are at least 80.5mm plus, and the stock head gasket gets to be to small, almost overhanging into cylinder.
Just throwing this in, If you make any, the head gaskets should be stock bore or overbore, bet more people will need overbore, as the arts are hard to find, and original bores even more rare.
good thinking.. im going to set my drawing up to reference a center point(in the center of the piston top) so i can resize the vector to cut out as big or small of a circle as i need.
also - on the pilot head gasket i have the cooling holes mapped, the 8 stud holes mapped... but what are the smaller holes for? I am going to draw them in either way
PostPosted: Thu Mar 25, 2010 12:06 am
thanks SpeedChaser
When I worked in the leather business we used these type of dies often to cut out several common pieces of leather... You would almost want a clicker or press to cut these!
PostPosted: Thu Mar 25, 2010 12:26 am
this laser method might have zero start up cost besides materials.. i don't think ray will charge me, i will exchange computer repair services for use of engraver.
He says it should keep the metal down even if i buy it in a roll...
anyways here is a scaled down image of the complete head gasket drawing
one with measurement mask layer and another without (not these are at 72dpi and not to scale)
PostPosted: Thu Mar 25, 2010 1:42 am
base gasket done here are scaled drawings
PostPosted: Thu Mar 25, 2010 8:16 am
look into copper flashing it by the roll
speed
PostPosted: Thu Mar 25, 2010 9:28 am
Tpreed
what cam software are you or ray going to use to get the math data off the jpeg
or the raster to vector software ?
I been look some thing simple to get math data off scanned jpeg
They make aluminum flashing by the roll too that is dead soft
thanks SpeedChaser :-)
PostPosted: Thu Mar 25, 2010 9:37 am
The corner holes are the only thing I can verify on the cylinder gasket and they are correct as you have marked them, the rest is just a guess your trying to measure something if you touch it the measurements vary .010 to .040 where you put the lines its not a straight line for me to measure from its all just a guess where it lands on the gasket.
The Pilot cylinder gasket thickness is .020
The same with the Pilot head gasket trying to measure over all on a radius or curve is all just a guess yeah looks close enough type thing, am I measuring EXACTLY where you marked it on the radius and bends? I really doubt it o its just a guess.
IMO the whole thing is a wash your just going to be guessing and will not know if they fit until you make one then fit it to the Engine parts.
Isn't their a scanning utility out their we can use to scan a true 1:1 scan my scanner no where does it give you an option of 1:1 so you know that's what your scanning.
IMO your wasting your time if you cant get a true 1:1 scan to work from?
All 3 layers of the Pilot head gasket measure .030 thick
PostPosted: Thu Mar 25, 2010 9:59 am
speedchaser wrote:
Tpreed
i am going to attempt in coreldraw as i have seen it work well in the past.
hoser, i was able to print the image at 300DPI and the measurements were spot on, the main bore opening was 3.190(81mm) on the actual paper so the scans and native resolution of my full size files are perfect
PostPosted: Thu Mar 25, 2010 10:09 am
Tpreed wrote:
speedchaser wrote:
Tpreed
Oh ok cool I never understood the scan thing lol
I was looking at the head gasket their is a lot of the gasket coating around the holes you want me to clean that off and scan again so the holes have a crisp edge?
PostPosted: Thu Mar 25, 2010 10:51 am
Tpreed wrote:
speedchaser wrote:
Tpreed
yea that rescan would be helpful for double checking measurements especially when i vector.. im thinking if the stud holes are a tiny tiny bit off the gasket will still work(like .009)
i might manually trace in illustrator to make sure measurements remain true. as of right now the head and base for FL400 are very very close as i measure lots of comparison distances between different objects to maintain accuracy the proximity of each item to another.
PostPosted: Thu Mar 25, 2010 11:15 am
Tpreed wrote:
Tpreed wrote:
speedchaser wrote:
Tpreed
Try this one I also put a machinist rule with it . 300 DPI
PostPosted: Thu Mar 25, 2010 11:30 am
awesome thanks
when making a copper instead of wafer would three layers be required? would one layer at .030 be too thin?
PostPosted: Thu Mar 25, 2010 11:41 am
Tpreed wrote:
awesome thanks
Make the copper one layer not 3
http://www.pilotodyssey.com/PO/view ... ead+gasket
PostPosted: Thu Mar 25, 2010 1:48 pm
I just about have the vector drawn up in illustrator.
Anyone have used pilot head and base to donate for comparison?
PostPosted: Thu Mar 25, 2010 2:41 pm
I have all kinds of used head gaskets they are steel and don't change much the coating on them just gets damaged, I have a few used cylinder gaskets but used they no longer lay flat and maintain their correct dimension, I scanned a new gasket.
PostPosted: Thu Mar 25, 2010 3:11 pm
Can you use a DWG of DXF?
I can digitize a JPG pretty quick in AutoCAD as long as I have two known points to scale the JPG to. I can then extrude it to whatever thickness you need and send the model back in BMP, DGN, DWG, DWF, DXF, DXX, EPS, RVT, SAT, STL or even WMF.
