It is currently Wed May 14, 2025 7:57 pm
 Post subject: eng mount
PostPosted: Sat Apr 03, 2010 1:09 am
any one have the eng mount brace that goes from the motor (( Internal Combustion Engine ? )) to the treans on the clutch side on top uses 2 bolts im missing it on my fl350 if you have a extra 1 could you sell it to me please ? thank you
PostPosted: Sat Apr 03, 2010 10:19 pm
man whats up ? did i get black balled or what ? no one wants to sell me nothing ? cant buy wheels, cant buy motor (( Internal Combustion Engine ? )) mount. no one wants to sell me any studs for my brake s ....! man what did i do ? ::-: :shock:
PostPosted: Sat Apr 03, 2010 11:40 pm
I never had good luck finding parts on the board unless the parts are already listed, I will give you the info of 2 guys that sell alot of used parts they are not the cheapest they know these parts are harder and harder to come by, good luck.
Nick, scvtelecom@sbcglobal.net
Erik, (425)750-5805 http://cgi.ebay.com/ebaymotors/Honda-Od ... ccessories
I have found it takes alot of patience finding parts.
PostPosted: Mon Apr 19, 2010 1:09 pm
Hey thanks for the info afastcar. i will give them a try ! i get a little excited sometimes ,and have no patience....! so i have to walk away and come back to it later , luckily spring is here and had some yard work to do. now im back to working on it again . wanted to have it done by now ... but that's the way it goes . im close and want to ride it ! thanks for the info. got to get it dirty.... ha ha take care . ::-:
PostPosted: Mon Apr 19, 2010 3:56 pm
Hey Porkchop. I might have the mounts you are looking for, Ill have to check. Do you have an extra CDI (Capacitor Discharge Ignition) box for the FL350? Maybe we can do some trading!
PostPosted: Mon Apr 19, 2010 7:17 pm
Are these what your looking for?
P1010294.jpg [60.69 KiB]
Downloaded 97 times
PostPosted: Mon Apr 19, 2010 7:18 pm
What kind of wheels and studs are you looking for??
PostPosted: Mon Apr 19, 2010 8:02 pm
Yep, that's what i am lookin 4 the top motor (( Internal Combustion Engine ? )) mount or brase ? i need one ! the clutch side or are they the same ?
also need the 4 studs that hold the rear disc to the hub on the trans .
and prob something else but have to get back to working on it. o yeah !!! 1) rear wheel have 1 nice one and one is real rough it is bent beaten and out of round would take alot of work to get it back it also didnt hold air it was so bent up. i could get some weld on bead locks to fix it with then it would work . Thanks
p.s. i don't have any extra parts what so ever, im trying to find all the parts i need to fix this one i purchased. but i am willing to buy those from you. thanks ::-:
PostPosted: Thu Apr 22, 2010 5:35 pm
I never heard from you, I have those items.
tires and rims right here in this section for sale from a great guy;
http://www.pilotodyssey.com/PO/viewtopic.php?t=7099
PostPosted: Sat Apr 24, 2010 12:20 am
HEY thanks ! yeah he seams like a nice guy . i only need 1 rear wheel 4 now . and the upper motor (( Internal Combustion Engine ? )) mount ,things you find when you get a unfinished project . spend spend spend.......
thanks porkchop
