It is currently Mon May 19, 2025 1:08 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Apr 03, 2010 11:10 pm
Tpreed wrote:
anyone want to scan a pilot trans gasket @300dpi? or send one to me?
The Pilot trans gasket is too large to fit on a scanner.
http://www.pilotodyssey.com/PO/view ... ans+gasket
Anyone have one they can send me, I have a 42" wide scanner at work.
PostPosted: Sat Apr 03, 2010 11:12 pm
Wait a second, I may have 3 sets of trans gaskets myself, need to check that...
PostPosted: Sun Apr 11, 2010 2:02 pm
updates ?
you cutting fl350 base gaskets yet :-)
thanks speed
PostPosted: Sun Apr 11, 2010 4:04 pm
speedchaser wrote:
updates ?
thanks speed
oh i havent forgot about this :)
ray is a busy man, he has to order the parts (lens and 02 tanks) the enable the machine to make smooth cuts in metals.. i am still researching alloys and such but so far here is waht i have
FL350 base .015 Al - soft alloy
FL350 head .009 al harder alloy for heat, also probably a copper one available at a higher thickness like .021
FL400 head will be .027 though copper
FL400 Base will probably be paper, i don't know what to make the FL400 base gaskets out of.. i would like to respect the stock port timings with the correct thickness.
anyone know the stock thickness on FL400 base? stock is wafer.. should i make aluminum or paper?
 Post subject: Re:
PostPosted: Thu May 30, 2019 3:52 pm
Tpreed wrote:
speedchaser wrote:
updates ?
thanks speed
What happened?
What happened to this project?
