It is currently Fri May 16, 2025 1:28 pm
 Post subject: redskinman crank rebuild
PostPosted: Sun May 02, 2010 9:34 pm
well got the rod kit and cranks in sat mail
Good packing on both
File comment: hoser pack them well
File comment: went with this one it seems to be in better shape on the seal area
MVC-363X.JPG [46.37 KiB]
Downloaded 214 times
MVC-364X.JPG [62.11 KiB]
File comment: add number
MVC-367X.JPG [101.91 KiB]
File comment: marked old pin rotation
PostPosted: Sun May 02, 2010 9:35 pm
next
MVC-369X.JPG [105.05 KiB]
Downloaded 211 times
File comment: little water damage
rust
File comment: little polishing up seal surfaces
File comment: this is cool they thread together
:) wonder if they will work like this
MVC-373X.JPG [77.7 KiB]
PostPosted: Sun May 02, 2010 9:41 pm
next
File comment: rod kit looks good
but came with shorter big end pin 56.3mm long
then the standard 59.6 mm long
MVC-377X.JPG [112.78 KiB]
Downloaded 208 times
File comment: Note this kit comes with a short big end pin
PostPosted: Sun May 02, 2010 9:47 pm
next
well I will try this with the short pin and see how it goes
It went pretty good got it with in .004
but it was stubborn after that
so will let it set and age and go back to it tomorrow
if all goes well it will be done then
I been doing a spec sheet as i go along
will post the final specs when done
thanks for looking speed
File comment: squaring up the first press
and pressing it to depth
MVC-380X.JPG [63.91 KiB]
Downloaded 205 times
File comment: assembling rod and thrust washers
MVC-381X.JPG [103.97 KiB]
File comment: all set in pressing fixture
with stop blocks
MVC-382X.JPG [68.86 KiB]
File comment: all pressed together and with in .004
try for 2 hr playing with it to get it closer but will let it set and age for a day then we will see if goes better
PostPosted: Sun May 02, 2010 10:00 pm
got all done
I posted spec sheets that you can barley read :)
I ship readable with crank and have hard copy for my self for later
will be shipping off to Hoser 5-3 or 5-4
thanks Speedchaser
PostPosted: Sun May 02, 2010 10:38 pm
thank you sir
Let me know if you wanna do that trade or if you want me to send you some money
thanks again
PostPosted: Sun May 02, 2010 10:56 pm
Looks great, I have some ready to go. I guess no one will know the effects of the short pin until running the motor (( Internal Combustion Engine ? )) and just seeing how it holds up.
PostPosted: Sun May 02, 2010 11:06 pm
Looking at your specs from your other post
viewtopic.php?t=7184
the 81-4 atc 250r has the shorter pin length of 56mm, seem like in that post you were wanting to use a cr250 rod kit .. any reason why the ATC kit was used instead ?
PostPosted: Mon May 03, 2010 9:30 am
http://www.pilotodyssey.com/PO/viewtopic.php?t=7184
note nobody make a rod kit for the fl350
as i seen with the right parts yet
this is what Honda used
Rod center to center = 125.3 mm
big end pin length 62.56 mm not available any more
stock Honda thrust washers 1.2mm Thick
so you are go to get thicker thrust washer or a shorter pin
THE PRO-X ROD kit for the cr25r 84-01 my come with the longer pin 59.6 mm and the 1.2 mm thick thrust washers
talked to Rocky Mountain http://rockymountainatv.com and they clarified the sizes
So as of right now if you see a rod kit for a fl350 watch what you are getting as noted above
speed
PostPosted: Mon May 03, 2010 3:26 pm
all done will be shipping soon to hoser
add pic's above
thanks SpeedChaser
PostPosted: Mon May 03, 2010 4:05 pm
add pic's above
thanks SpeedChaser
Do you have any 10-32 set screws about 1/4" long? If so can you throw 3 of them in with the crank, they hold the cutter on my boring bar and the hex is getting warn on them, I have all kinds of 10-24 and a bunch of 10-32 cap screws just no set screws for some reason...
PostPosted: Tue May 04, 2010 11:51 am
add pic's above
thanks SpeedChaser
http://www.youtube.com/watch?v=VmZ35VCV978
THANKS SPEED!
PostPosted: Wed May 05, 2010 5:42 am
Hey Speedchaser how do you go about correcting run out?
PostPosted: Wed May 05, 2010 8:02 am
big hammer :)
but yes it is amazing how easy is to move the run out on a new pressed together crank
but some time it a pain because you my be fighting a .001 back and forth
lead hammer or a dead blow seem to do the trick tho
speed
PostPosted: Wed May 05, 2010 8:17 am
speedchaser wrote:
big hammer :)
speed
I use to have a magazine article from the 70's or early 80's that showed in detail how to adjust a crank I wish I could find it, I looked all over and cant find it, anyways they had a series of soft face hammers they used, lead, brass, rawhide, plastic face dead blow... A different weight hammer was used depending on how much adjustment was required.
PostPosted: Wed May 05, 2010 3:26 pm
Crankshaft arrived via USPS no shipping damage as usual perfect professional packing by Speedchaser I am saving the box and all the packing materials to send you a few more cranks in the future...
Just took a quick look at it everything looks ok I will look it over good before installing tomorrow.
That is the crank Stix sent that he questioned the rust on the small end of the rod and I was skeptical about the big end I am glad we condemned that rod assembly it would not have lasted very long if run in that condition (more pics later of old rod) and redskinman would have ended up pissed off for sure.
Here is the crank installed in Redskinman's 350 bottom end ready for action, sorry about the crappy pic.
PostPosted: Thu May 06, 2010 6:27 am
speedchaser wrote:
big hammer :)
speed
I was going to suggest that as a joke :-)
PostPosted: Wed Feb 22, 2012 2:06 pm
is there a way to get clearer pictures of measurements for crank rebuild??
PostPosted: Wed Feb 22, 2012 2:46 pm
I cant help you with the pics.
I still havent used this crank,which is a good thing,i'm still using the complete Engine I bought off ebay for less than 300 bucks shipped{it had a jb weld spot on it and that must have scared off all the bidders}
So I still have this rebuilt bottom end along with a new top end on the shelf when this Engine does go :-)
PostPosted: Wed Feb 22, 2012 4:15 pm
has anybody ran an Engine with smaller crank pin??
PostPosted: Wed Feb 22, 2012 4:33 pm
cvs1223 wrote:
has anybody ran an Engine with smallr crank pin??
q
Hello if the crank has been rebuilt it will have the short pin. No body makes the stock Honda lenght pin for the for the fl350
Thanks speed
PostPosted: Wed Feb 22, 2012 4:42 pm
Part number for correct pin length
Vesrah Crank Rod Kit FL350 R Odyssey 1985 Honda
VA-5001
PostPosted: Wed Feb 22, 2012 4:54 pm
im just going off what my mechanic/machinist is telling me. an he says should not rebuild with shorter pin which is almst 1/4 inch shorter. could cause premature twisting ect.
im still a newbie to all this
Registered users: Bing [Bot], canadian oddy, eseymour72, Google [Bot], Lanix, liduno, wyeeoddy
