It is currently Mon May 19, 2025 1:20 pm
PostPosted: Sat May 29, 2010 4:39 pm
OK, so I had to take a spindle of the front of the pilot to fix, I had to use a fork to get the upper ball joint apart and damaged the dust cover, is there a replacement or am I SOL?
PS is there a thread for alternative parts for Pilots and Ody's?
PostPosted: Sat May 29, 2010 6:00 pm
As you probably have figured out by now the fork tool is a DESTRUCTIVE tool it was meant to be used on parts you were removing and throwing away, I strongly suggest you take the fork and throw it in the garbage its a tool you should have never bought in the first place, keeping it in your garage will just encourage you to do more damage in the future to something else, its a tool that should come with a big sign saying USING THIS TOOL WILL TURN PARTS INTO JUNK not that it would keep people from using it lol.
Their are other easier NON destructive methods to remove a ball joint and not damage anything.
Do a search for ball and joint and boot everything in the bold letter including the AND their has been a lot of discussion about this in the past here is one viewtopic.php?t=237&highlight=ball+joint+boot
PostPosted: Sat May 29, 2010 6:45 pm
Ya, I knew it was destructive when I gave up on the method on whacking a through away nut, Could not get a good shot at it and was not working on the bottom either.
I really did not think it would be so difficult to locate a replacement. whent to the local honda dealer, it looked like the seal on a TRX450 was about the same, they don't sell them for those either.
Going to call the local honda auto dealer to see if they have any in stock. P/N 53348-611-310
Thanks,
PostPosted: Sun May 30, 2010 1:36 pm
Soak it in PB Blaster for a couple days, then use a Big hammer on the arm and end and hit it, it will break.I would look at the trx 450r arms as well for replacements on the boots.
PostPosted: Sun May 30, 2010 1:54 pm
Bike bandit has replacement ball joints for less than $20/side, upper and lower. that may be the direction I head for the seals but I'll look at the auto parts store "help 13561" item tie rod dust boot.
PostPosted: Sun May 30, 2010 2:10 pm
Replacement ball joints?? Your going to cut out the old and weld in the new?
PostPosted: Sun May 30, 2010 8:26 pm
No, I'm just thinking to buy the new ball joints, remove the dust seal and use it on the pilot.
opted to go with the $4.99 fix from Autozone, item # 13566 in their help section, found it through the link that you had posted earlier. it seems to work good, I pushed it on further that the step that the original boot fits as that was sort of loose.
PostPosted: Mon May 31, 2010 8:25 pm
Just an update on the "super glueing" of the ball joint covers. Its been 6 years since I glued my covers on and none of the 6 covers I installled have ever come loose.
PostPosted: Tue Jun 01, 2010 3:51 pm
That's good news as I acquired everything I needed to replace the boots on one of ours and glue them up in February, but never got around to it.
