It is currently Thu May 15, 2025 4:13 pm
PostPosted: Sun May 30, 2010 7:49 am
Just picked this 86 250r ATC up from Mike's place today-big thanks to Stoneman for lining this ride up for me.It has a spare motor (( Internal Combustion Engine ? )) that is totally wiped out but the extras alone on the rear suspension make up for it.The swinger, axle, rear shock alone are worth the purchase price. I installed the rear tires and rims as the ones that came with it were a joke-the plastics are all going to be replaced-the rear carrier bearings are shot, motor (( Internal Combustion Engine ? )) won't run currently-looks like the coil has issues.It is missing the front headlight totally,but I can rehab this thing just fine.Carb, reed cage all look stock.Here is some pictures:
File comment: plastics were totaled,I took seat off and threw them out as soon as I got home!
File comment: motor (( Internal Combustion Engine ? )) does not run currently, might need a plug or coil, checked it out alittle bit yesterday-need a comp check today.
File comment: west coast extended swinger, these things are hard to find!
File comment: pipe is a Paul turner atc type 6 one of the best for my riding style
File comment: rear view, carrier is stock, need to replace with a RAD or double row carrier in there.
PostPosted: Sun May 30, 2010 8:00 am
Nice score Greg. :-)
The rear sprocket and chain look toast tho.Look at the wear on those teeth.
Like waves curlin' in before they shore/ break! ...Baz
PostPosted: Sun May 30, 2010 8:33 am
Can you swap ignition parts with your other one to test? Most the weak spark problems I have seen were bad connections.
PostPosted: Sun May 30, 2010 8:45 am
oh for sure, it will all be replaced-I started the ROCKY MTN order last night!
PostPosted: Sun May 30, 2010 8:49 am
Oh yes-I got spares for most of the ignition parts, so it will be replaced or I'll ohm test it with the meter.I got plastics from another machine(WIGGINS RIDE) that will be installed and I'll get new for his ride-chain, sprockets, etc all new.The motor (( Internal Combustion Engine ? )) is gonna be CSI'D to see if it gone or not ASAP, or as soon as the TECATE is jetted right.
PostPosted: Sun May 30, 2010 10:50 am
the Engine started everytime on the second kick here :shock:
i rode it down the street and it was eye watering fast :shock:
we did run thru 2 hrs of hard rain on the way to gncc?
PostPosted: Sun May 30, 2010 6:02 pm
Plug cap was off the plug,and I did not like the gas,drained it, will CSI more tomorrow hopefully.Need to do the basics on it first-drain fluids, etc, and simple checks on it.
PostPosted: Sun May 30, 2010 7:52 pm
holy cow batman, looked up some prices tonight-the side case alone is big money;
CRANKCASE ASSY., R.
196594-001 Enter 0-99 $384.45
CRANKCASE ASSY., L.
Fr_Sr_No_To 2502532
196598-001 Enter 0-99 $392.35
that's from BIKE BANDIT.COM I could not get onto the SERVICE site.Does anybody know of the the trx 86 model year cases are the same by chanceI can rebuild the complete bottom end soup to nuts for those prices!!
PostPosted: Sun May 30, 2010 7:56 pm
CRANKCASE ASSY., R.
CRANKCASE ASSY., L.
Fr_Sr_No_To 2502532
You need that take out new bottom end you had...
PostPosted: Sun May 30, 2010 8:49 pm
CRANKCASE ASSY., R.
CRANKCASE ASSY., L.
Fr_Sr_No_To 2502532
I have 1 but it is a 85-I would prefer to keep it all 86-I could take the motor (( Internal Combustion Engine ? )) out that's in there and send that one instead---------
PostPosted: Mon May 31, 2010 7:42 am
Congrats trike Master
are you going to start your own trike nostalgia raceway?
Can you put the 310 kit in that
Regards
PostPosted: Mon May 31, 2010 9:30 am
I can install a Big bore kit yup, but won't.It got plenty of power already!!
Got it to run this morning, was a plug and coil issue-did not check compression as of yet, changed the oil, drained the antifreeze and put new in it, installed new UNI-FILTER, little stuff like that.
PostPosted: Mon May 31, 2010 9:31 am
CRANKCASE ASSY., R.
CRANKCASE ASSY., L.
Fr_Sr_No_To 2502532
I think the difference between the 85 and the 86 was the color of the paint of the Engine?
PostPosted: Mon May 31, 2010 4:47 pm
basicly yes-the 86 had the upgraded clutch, and the gears are slightly different as well, small differences between them.
PostPosted: Mon May 31, 2010 5:27 pm
I bet one of the jokers at the gncc pulled the plug cap off or it fell off mikes trailer and he forgot to tell you.
I told you that thing flys! :-)
PostPosted: Mon May 31, 2010 5:41 pm
It was off Stoneman, but I was lucky and checked it first before I proceeded on the CSI. I had no time today to go on with anything really, had to work for some hrs-emergency thingy for the boss- hpoing to get more involved with it during the week.
I'll post the compression, air leak test, etc when I get them here-more to come!!
PostPosted: Tue Jun 01, 2010 3:01 am
Nothing wrong with that set , they are only half way through their life :shock:
Just turn them around and go again :-)
PostPosted: Sun Jun 06, 2010 9:33 am
Have not had anytime to check into this ride at all.Hopefully soon.I ordered some items for it, sprockets/chains,air filter,grips, handlebars,new controls, fork seals,fork boots, seat,and a DESERT tank from Clarke.I will order more for the motor (( Internal Combustion Engine ? )) if needed.Air leak test and compression check results coming soon.
PostPosted: Wed Jun 09, 2010 5:20 am
TRX and 85 ATC cases are discon only the left hand 86 case is still available right hand case gone too.......also the only 85/86 difference is the color on the cases the gears didn't change until 87....
PostPosted: Wed Jun 09, 2010 9:14 am
Thanks, I need the left side case for my 86 motor (( Internal Combustion Engine ? )). I want a 86 case to match the OEM 86 look, I have a 85 motor (( Internal Combustion Engine ? )) in the ride now, nbut being so anal I really want the 86 colored motor (( Internal Combustion Engine ? )) in it- you would be amazed as to prospective buyers when they loolk at the atc, they immediately see a black cased motor (( Internal Combustion Engine ? )) and tell you that the atc is a 85 - or that the atc is not worth the asking price due to the 85 motor (( Internal Combustion Engine ? )) instead of a 86! They do not have a clue. But, as I said it hurts resale for some stupid reason.
PostPosted: Wed Jun 09, 2010 9:21 am
Buy the paint from Honda and paint the cases.
PostPosted: Mon Jun 28, 2010 7:53 pm
Hoser, any updates on the motor (( Internal Combustion Engine ? )) by chance? :-)
Ordered new plastics, sprockets,chain,rear carrier bearings, front headlight bezel and light, OEM switch,handlebars, tires and rims,new carb,air filter,and of coarse the motor (( Internal Combustion Engine ? )) is getting a CSI from Hoser.
PostPosted: Sun Aug 01, 2010 8:37 pm
Got some time today to check out the ride.First, got no spark, fuel is crap, air filter is done,expansion chamber is damaged,wire harness is cut by the headlight,chain and gears all bad-cold compression is 190 fully opened throttle,a ton of "shade tree mechanic" stuff on this ride-fork seals bad,rear bearings need replacing as well.I had a pretty new set of plastics I had off WIGGINS old 250r ride, so I installed them on it.I stripped the exhaust, all the fluids, rear swinger,kicker,gear shifter for replacement with OEM parts.I will be ripping into it more this week.
Ordered a new FMF fatty full exhaust system, I will be using that for another ride I have and transferring the exhaust it has which is a Paul Turner ATC TYPE 6 full exhaust on this ride.I will be looking forward to getting into the rear swinger on this as it has a WEST COAST +4 on it with a stock carrier.
PostPosted: Sun Aug 15, 2010 10:23 am
ServICE Honda order came in today,lots of nuts, bolts, OEM rubbers,headlights,bezels,etc for this project.I am actually installing these new parts on WIGGINS ride and using the parts off that ride on this,currently the ride has no spark and I cannot locate the issue.I am leaning toward a bad on/off switch(hopefully).
PostPosted: Fri Sep 03, 2010 9:48 pm
got the ride running today, drained fluids and changed them all,the crankcase had ATF in it-did a quick ride around the yard-installed a used handlebar control,new seat, all new seals for the pipe WITH SPRINGS,alot of smaller stuff.
Registered users: Baidu [Spider], Bing [Bot], c5racer, Google [Bot], liduno, Rppjr
