It is currently Mon Apr 28, 2025 8:04 am
PostPosted: Thu Jul 15, 2010 6:40 pm
Hello went to a company that I do work for
They make steel rule dies there
They built me a die for the fl350 cylinder base gasket
here are some pic's
the part folds in because of the soft aluminum
then I have to flatten it back out in a 50 ton press
pretty neat stuff
thanks for looking
SpeedChaser
File comment: die board all laser cut
File comment: punched part before flatting it back out
I can cut the parts so they don't do this but it is hard on the die and they flatten back out just fine
File comment: finished part after flatted out in press
File comment: some stamping
PostPosted: Thu Jul 15, 2010 7:32 pm
Soon to be for sale section Speed? :-)
PostPosted: Fri Jul 16, 2010 12:17 am
nice I want some. should I guess that head gaskets are in the works too ?
PostPosted: Sun Jul 18, 2010 6:45 pm
Sure is different from the days when I used to work for a gasket manufacturer. We didn't have the luxury of laser cutting the dies. That one looks pretty sweet!
Just curious, can you take the punch pins out of the die and make them without the vent holes? This way you would not have to plug the vent on the stator side to keep the oil out of the starter. If the gasket was made with a hard enough material, you could use a small screw and nut with some locktite to plug the hole so the oil could not pass through to the stator side.
If they do come up for sale, let us know, I would be interested in a couple.
PostPosted: Sat Aug 21, 2010 2:39 am
got 2 man there nice it's a no brainer
PostPosted: Sun Aug 22, 2010 1:34 pm
Got my gaskets nice job sir!
