Ok, the week away was run & lost by me mainly!
Went up to the bush for a break & had a rip snorting good time.
Don't have many pics of being away as I forgot my camera. Got a phone pic only.
Still on my ute with a little brown coating. Had a fight with a muddy wet dam.
Before the mud bath. With my phone.
Had a mishap with a stick in the same tire I pierced previously.
This sneaky little rim dented itself on me.
Must have been the hard right hander. I have to get a helmet cam to film this track & my other regular track. It was blocked by two large fallen trees.
Did a bit of other work, like adding the fuel pump & getting it to work.
The T-piece one way valve thing, failed. So, I plumbed the pump directly to the carby with my glass filter between the pump & filter. Worked perfectly too.
The pump wouldn't bolt on to the other hole due to the air intake obstructing the pumps position.
New rear skid plate nicely powder coated thanks to my bro. Thanks bro.
Great clutch protection.
New Roll cage powder coated also from the bro.
Cleaned up today.
Decided to use the old empty dam as a jump in my imaginary circuit. Overshot the jump & ended up running over some old fence wire including barbed which became tangled around the back right & front left wheels. No pics though. Took an eternity to untangle the wire.
Power pros pipe goes really well, but, have come to the conclusion that these tires I'm currently using are not very suited with the larger diameter & width.
