It is currently Sun May 18, 2025 2:25 am
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Dec 31, 2010 1:19 pm
Radiator over flow tank could be something as simple as a water bottle with a hole drilled in the cap for a hose to slide into, probably not all that durable but something to get you running.
Once the system is full and all air out you wont need much of a reservoir or much volume for that system.
Do a search on evilbay for one here is a search I did for TRX over flow and it returned a bunch find something that looks like you can install, search for other ATV's and bikes I am sure you will find something cheap.
http://shop.ebay.com/?_from=R40&_trksid ... over+flow+
http://shop.ebay.com/i.html?_nkw=honda+ ... m270.l1313
PostPosted: Fri Dec 31, 2010 2:03 pm
There you go,that looks perfect.
PostPosted: Fri Dec 31, 2010 2:52 pm
Is there a stator in there?
exhaust port
intake side
base spacer plate..3 mm thick
the extra stator that came with the 420..I bet it is the same as the one inside..same plug
the 420 piston roughly 88mm
that's what I have... I need to work on getting the flywheel off
as I hoped...minus a couple wires..just need the factory plugs
PostPosted: Fri Dec 31, 2010 2:56 pm
Whats with the bottom of the piston skirt in this pic it almost looks like it was rocking in the cylinder bore and catching in a port opening?
PostPosted: Fri Dec 31, 2010 3:00 pm
there was 1 mm difference between the piston and the jug!
K-BOOM!!
THe person that sold them to us,ran several races with them before removing
PostPosted: Fri Dec 31, 2010 9:05 pm
It's a 36 carb just like you wanted!!!
Here are pics from phone
File comment: Hard to hold and snap!
PostPosted: Fri Dec 31, 2010 9:17 pm
Another
PostPosted: Fri Dec 31, 2010 9:20 pm
I can only do one at a time!
PostPosted: Fri Dec 31, 2010 9:24 pm
Let me know if this is what you're looking for!
PostPosted: Sat Jan 01, 2011 9:01 am
did U say this is your stock pilot carb or off a dirtbike?
PostPosted: Sat Jan 01, 2011 10:00 am
this is a 36mm off the dirt bike... I used it in the pilot for a bit... Went with the 39mm instead on the pilot...
The stock pilot is a 34mm if you want that???
PostPosted: Sat Jan 01, 2011 10:38 am
OK, The charging system is done
Thank God im a packrat
PostPosted: Sat Jan 01, 2011 10:43 am
you will remove the black cap on the vent line above the starter won't you??? It needs to have a vent line on it...
PostPosted: Sat Jan 01, 2011 10:45 am
Maybe..He,He
Give me a call
BTW,the bore on the jug is 88.5 mm
I need a new piston..any ideas?
PostPosted: Sat Jan 01, 2011 10:55 am
KUDA wrote:
Maybe..He,He
Give me a call
call wiseco... it will have to be custom made, unless you can cross reference the numbers off the box...
I'll call ya later I'm drinking coffee still...
PostPosted: Sat Jan 01, 2011 12:08 pm
KUDA wrote:
Maybe..He,He
Give me a call
What are the numbers on the top of the piston?
PostPosted: Sat Jan 01, 2011 12:24 pm
really hard to make them ou but..
1 00mm
478 p4
td
found 1 on evilbay
88.5 mm kit for $150 shipped
PostPosted: Mon Jan 03, 2011 8:50 am
Ok,I should have the base gaskets in from speedchaser today or tomorrow, o rings by wed or thurs
36mm carb by then too I hope,{TURBO},Then she goes together!
got a couople of radiators coming, a banshee from bogger,and a gold wing 1200 with fan from evilbal
so with that being said,I think I have covered all my bases!!!!
I will be posting some more pics of my progress
Thanks to all that has helped so far!
We get this one done..THEN it's 420 time!
Ed
PostPosted: Mon Jan 03, 2011 10:22 am
Glad to hear she is getting close. Be sure to use a quality synthetic oil, around 32:1. Do plug chops n watch the EGT to get the jetting correct at all rpm ranges. I would also write down everything including compression after rides to make sure nothing is changing. When its together, let me know what your squish is please.
Good luck!
Gary
PostPosted: Mon Jan 03, 2011 5:37 pm
Will do! you'll be hearing from me
PostPosted: Fri Jan 07, 2011 12:38 pm
The 360 is almost there, waiting on the new intake and orings,should be here today!
P.S.
Turbo
Carb is out
PostPosted: Sat Jan 08, 2011 3:23 pm
well the 360 is together,time to install and start figuring out the exhaust and cooling!
anyone hear of BV, see sticker on liquid cooled jug :-)
Image :shock:
PostPosted: Sun Jan 09, 2011 12:10 am
well,The motor (( Internal Combustion Engine ? )) is in, doesnt look like my bills pipe will fit,so Looking at other options
will post pics sunday :-)
PostPosted: Sun Jan 09, 2011 12:33 am
fuel tank in the way??? Or the frame???
PostPosted: Sun Jan 09, 2011 10:10 am
pics:
looks like I will be useing the old pipe for now, ANYONE know what pipe this is???????,thought it maight have been a DG,No Tags on it anywhere
WAY to COLD out right now to work 8 degrees
my front yard this morning!
BURRRRRR :shock:
guess I'm not living south enough!
Registered users: c5racer, Google [Bot], Lanix, liduno
