It is currently Mon May 19, 2025 3:19 pm
 Post subject: Goldwing radiator
PostPosted: Sat Feb 19, 2011 1:12 pm
I know at least one person (turbotexas) who runs a honda goldwing radiator and fan set up on there odysseys, and i was wondering 1. if any body else had gone this route? 2. Was mounting it easy? Did it fit in alright? and 3. Does it work very well? Would it just be overkill for wyoming? Thanks!
 Post subject: Re: Goldwing radiator
PostPosted: Sat Feb 19, 2011 8:28 pm
Yep,I have one too,Easy to mount,does a great job cooling
cheap on ebay,just make sure the one you buy is in good shape.,I think mine is an 86'
I have about $65 in it shipped
PostPosted: Sat Feb 19, 2011 11:28 pm
There was one one ebay for about 25ish dollars shipped. hoping to snag that up :-)
PostPosted: Sun Feb 20, 2011 12:27 am
Only bad thing about the goldwing is there is no threaded bung for the fan switch... But easy enough to include on in the hose line...
PostPosted: Sun Feb 20, 2011 1:40 pm
I did think of one other question, do you guys run coolant pumps on your set ups or do you just let it thermosiphon?
PostPosted: Sun Feb 20, 2011 10:21 pm
Thermo and a fan switch is all you will need... No need to put another electrical draw on the battery, OR have it FAIL without you knowing the pump quit...
PostPosted: Mon Feb 21, 2011 12:32 am
Do either of you guys have pictures of where you mounted your radiators? Just kinda want to get some ideas
PostPosted: Mon Feb 21, 2011 6:54 am
Here's the thread of one of ours, I have a second one ready and waiting for the time to install and will make the bottom bracket slightly different on that one so the radiator outlet lines up better with the heads inlet.
viewtopic.php?f=5&t=2526&hilit=radiator
PostPosted: Mon Feb 21, 2011 11:41 am
viewtopic.php?f=5&t=2526&hilit=radiator" ."..
Thank you! that's actually exactely what i was thinking about doing.
PostPosted: Mon Feb 21, 2011 10:23 pm
just won a gold wing radiator with fan for $17 shipped. Should get it in about a week
