It is currently Fri May 16, 2025 6:49 am
 Post subject: dial a jet
PostPosted: Mon Feb 28, 2011 12:05 am
looking to buy a dial a jet and possibly and 39 pwk..
 Post subject: Re: dial a jet
PostPosted: Mon Feb 28, 2011 12:19 am
do it... great results in both my ody and Pilot!!!
I even installed the dial a jet into the twin carbs on my Triple eee
PostPosted: Mon Feb 28, 2011 12:25 am
yeah i think it would sure beat pulling the carb every time you need to change a jet
PostPosted: Mon Feb 28, 2011 12:28 am
I go all over the states, and it has been easy as all get out to change my jetting for altitude weather etc...
PostPosted: Mon Feb 28, 2011 12:32 am
where did you get them from turbo and if you don't' mind how much were they
PostPosted: Mon Feb 28, 2011 8:10 am
Atvracing for the carb, and thunder products for the dialajet...
Don't remember???
PostPosted: Mon Feb 28, 2011 12:31 pm
Try SUDCO on the carb most places your going to buy a carb from call SUDCO and they drop ship it to you, you end up paying them 30-40 bux for ordering it for you http://www.sudco.com/index.html
PostPosted: Mon Feb 28, 2011 5:09 pm
http://www.carbparts.com/index.html. take a look
PostPosted: Wed Mar 02, 2011 5:53 pm
found a 39 pwk ready to run all cleaned just need jetted to my area..the guy said $150 shipping..is that a good deal
PostPosted: Wed Mar 02, 2011 10:53 pm
Yes! Hopefully 1frc can read the nEedle jet in his current setup and you can match that!
PostPosted: Fri Mar 11, 2011 11:05 pm
Hey Turbo, Was it hard to set the dial-a-jet in? do they have a pretty good set of instructions to do so? What do they have you do throw a big jet in it and then the DAJ does all the work?
PostPosted: Fri Mar 11, 2011 11:50 pm
easy to install on a kiehen... harder on the mikuni because of how they are made...
First thing to do is to Jet the carb to what you need, then they say to drop one or two main jets and install the dial a jet! Then you will want to do the plug chop again to insure it's all good then go enjoy the ride...
I am headed back to vegas!!! Should be there Thursday!!!
