It is currently Mon Apr 28, 2025 8:06 am
PostPosted: Thu Mar 03, 2011 10:20 am
Hello I had time to share on one way of fixing the screwed up Tapped Hole
by not weld it up .
so Thank you for taking a look :-)
SpeedChaser :-)
File comment: threaded hole for the stator
one of the hole was drill on the side of the bolt that broke off in the case
File comment: I took a scriber or pointed tool and prayed out a piece of the old screw that they broke off in the case
File comment: got most of it out note how the hole is off center now we need to see what size of hole we have .
it looks like i can put a 5/16 taped hole in there after i try to center up the hole.
File comment: got some 5/16 aluminum rod off the shelf or you can try to find some aluminum threaded rod or a screw
I used the rod and will thread it to what i need
File comment: ended up using a 5/16-25 threading die
SpeedChaser :-)
File comment: well thread the rod keep it straight
File comment: turned out good good to go
File comment: Time to straighten the hole a little
before i try to tape the hole but don't go to far
File comment: not to bad of a taped hole
make sure up tap all the way to the bottom of the hole
SpeedChaser :-)
File comment: test the threaded rod make sure it fit all the way in
File comment: get out your retaining compound
the stuff i use is loctite 680
but this can be done with out it too
I just don't what it to come out
File comment: put some on there then thread it in and bottom it out tight but don't strip it out
File comment: well time to cut it off and leave about 1/8 to 3/16 high
File comment: all cut off
Time to get primitive
SpeedChaser :-)
File comment: Time to get primitive
File comment: now tap on the top of the threaded rod that you cut off
just enough to mushroom over the top off the stud
File comment: what this dose is it pushes the metal
to the out side wall of the tapped hole so it will not come out or turn.
this is how we plug holes in steel that we need to move or do not need any more
File comment: now cut off the rest of it and grind or file flat
File comment: now I use transfer punches
to find center
PostPosted: Thu Mar 03, 2011 10:21 am
next
SpeedChaser :-)
File comment: find the right size and line it up on the other hole so you get the just of it
File comment: this what it looks like on the end of the transfer punch
File comment: line it up
File comment: make sure its lined up
then give it tap with a hammer
File comment: that is what it should look like
SpeedChaser :-)
File comment: now lets see what size drill we need for a 6mm x 1
File comment: OK its a #9 or a 3/16 witch would be a little tight . I always use a smaller drill bit to pick up the prick punched hole because the bit will bend a little in this case i would use a 1/8" dia or smaller . now just drill in a 1/4" to 3/8 deep. then go to the bigger size drill bit
File comment: now take to tap drill and stick it in the other hole and put a spot of paint on it so you can see how deep you need to go
File comment: drill your hole straight in use a drill press or hand drill this time i used a hand drill
File comment: now chamfer the top of the hole
with a chamfer bit
thanks for looking
SpeedChaser :-)
File comment: all chamfered up
File comment: all taped and look new
PostPosted: Thu Mar 03, 2011 10:22 am
just in case i need 8 spots
well got in seven :-)
SpeedChaser :-)
PostPosted: Thu Mar 03, 2011 4:33 pm
wow that turned out really good..always wondered how to fix a stripped out hole..i have a couple that could use repair
PostPosted: Thu Mar 03, 2011 5:47 pm
thank you for the lesson master SpeedChaser
PostPosted: Thu Mar 03, 2011 9:26 pm
Simply amazing. Really is. I can't remember if there are any other threads on that case in need of repair Speed.Thanks for noticing that for me!!!!
Those punches are sweet, are they a common sold item by chance?
PostPosted: Thu Mar 03, 2011 10:09 pm
SpeedChaser
Would you think JB weld would work or is loctite better.
Eagles17
PostPosted: Thu Mar 03, 2011 10:23 pm
You Can get a set from harbor freight for $10.00 - I'm sure they are not the best if you only use them afew times the price is right.
http://www.harborfreight.com/catalogsea ... sfer+punch" ."..
These are real nice if you make your own gasket - put the gasket on a block of wood and hit with a hammer and you got a hole.
http://www.harborfreight.com/9-piece-ho ... -3838.html
PostPosted: Fri Mar 04, 2011 10:50 am
That is an interesting way of fixing stripped holes that I hadn't considered before, thanks for sharing. I see the main advantage is if the damaged hole gets off center, you can get it back on center this way.
Have you ever used steel thread locking inserts? http://www.mcmaster.com/#threaded-inserts/=baccxj The ones with the keys work great. The only issue is finding one that has the right thread sizes for the application, and your hole must be on center to start with.
PostPosted: Fri Mar 04, 2011 12:23 pm
When I was just a young puppy I was a precision assembler of circuit board drilling equipment and we used these inserts on aluminum guide rails. Once they're in they're permanent and harder than a whore's heart! LOL! Work Great!
We used to call them Keenserts. It was probably the manufacturer's name.
Hat's off to ya Speed, that's an excellent fix for an area that you can't use an insert in!
Thanks for posting this....
PostPosted: Fri Mar 04, 2011 4:00 pm
Great fix! Would a helicoil essentially do the same job?
http://www.google.com/products/catalog? ... DQQ8wIwAg#
PostPosted: Fri Mar 04, 2011 5:33 pm
http://www.google.com/products/catalog? ... DQQ8wIwAg#" ."..
Normally if the hole was just stripped out you could possibly tap the hole to the next size larger screw or use a heli coil or an insert but in this case with the hole now off center due to damage. this is a great way to get the threaded hole back to it's original position.
PostPosted: Fri Mar 04, 2011 5:47 pm
Yes Keenserts is a brand. I have found they are easy to remove. Just drill them out to a specified size and the keys can be pulled out and the remaining insert unscrewed. But they are steel so they are harder to strip out than aluminum. We used them on a prototype vehicle at work because we didn't want to worry about stripping aluminum threads out.
In my limited experience helicoils suck. I would use speedchaser's method or the thread inserts before helicoils.
Exactly. Props to speedchaser for this tutorial.
PostPosted: Fri Mar 04, 2011 6:31 pm
I have had to use heli coils for an emergency temporary fix for a VW head where the spark plug was stripped out. The heli coil lasted about an hour before the spark plug blew right out of the head with the heli coil still attached!
Needless I'm not a heli coil fan either!
PostPosted: Fri Mar 04, 2011 8:37 pm
http://www.locknstitch.com/sparkpluginserts.htm
My kid flooded the VW once so had him pull the plugs when he did 2 out of the 4 the threads in the heads were bad, pulled the heads and bought a spark plug insert kit from NAPA and repaired all 4 holes.
PostPosted: Fri Mar 04, 2011 9:15 pm
If you're going to do it, inserts are the way to go!
