It is currently Mon Apr 28, 2025 4:44 am
PostPosted: Sat Nov 08, 2008 9:28 pm
Hello
rework repair Knuckle for Trackside
started to day knuckle is not that bad one side looks pretty good other side
need a lot of weld
well let get started with the pic's
thanks for looking
speedchaser
File comment: the shipping box had a hole
but every thing is still there
File comment: close up
Nice tape there Trackside
File comment: before pic
this is the better side
File comment: next closer
File comment: weld up the good side first
PostPosted: Sat Nov 08, 2008 9:30 pm
Trying some thing a little
different this time around.
By putting it in dry sand it will
hold the heat in the part longer
and will have less hard spots.
well that it for today more tomorrow
thanks for looking
SpeedChaser
File comment: bucket of dry sand
PostPosted: Sun Nov 09, 2008 2:27 pm
Well here is the bad side
every thing went well
The bucket of sand worked great it held the heat in the part a lot longer witch helps on the cooling
if the part air cools down to fast the cast steel will get hard
thanks for looking
SpeedChase
File comment: wow that ground out a lot
File comment: all weld up and in the machine
and by the way the bucket of sand
work the best it held the heat in for hours No hard spots this time around
File comment: all machined up and ready for bearing and seals and don't forget the spacer
File comment: bearing seals spacer all in
check Gage fits nice
File comment: all box up and will go out on Monday 10th
yea I fixed the hole in the box too
PostPosted: Sun Nov 09, 2008 2:30 pm
SWEET! Another Honda Pilot hard part saved from the dumpster!
Excellent work !
PostPosted: Mon Nov 10, 2008 12:15 am
You do some great work.
PostPosted: Mon Nov 10, 2008 5:18 am
Amazing
PostPosted: Wed Nov 12, 2008 6:41 pm
Great job Speedchaser! The knuckle looks awesome, and thanks for the bargain price. Glad you were able to fix the whole in the box too, even though you did not have any Trackside tape to work with.
Trackside
PostPosted: Wed Mar 30, 2011 11:27 am
Do I need to send bearings and seals with the worn knuckle?
PostPosted: Wed Mar 30, 2011 1:25 pm
yes please
thanks Speed
Registered users: FL670R, Google [Bot]
